Author Topic: Voltcraft VC850 - hack Max/Min button and Sleep function into multimeter  (Read 463 times)
Offline trying to be cleverTopic starter
  • Country: pt
I recently got a Voltcraft VC 850. While reading an older post about it in this forum, I found out that it might be possible to add Max/Min and Sleep functions into it.
They also state in the data that the ic shall have sleep mode guess it's been disabled can it be pin 94? (txen operation = low and sleep = high) so if i am not mistaking pulling this pin high with like a 10k resistor will that give the ic the sleep option then?
When I turn on the multimeter, all the LCD characters light up for a few seconds, and I can see a "MAXMIN" symbol that it's never used and it's not mentioned in the instructions manual. Could this symbol be supposed to be used with the Max/Min functionality?
I've attached a picture with the symbols that are unmentioned in the instructions manual in red.
Has anyone done these mods?
« Last Edit: April 27, 2022, 10:54:31 pm by peido »
