Author Topic: 121GW no backlight (button?)  (Read 636 times)
Offline int2str
« on: September 29, 2018, 10:17:42 pm »
Holding the "Mode" button doesn't turn on the backlight at all.
Anything I'm missing? Or is my backlight broken somehow?
Offline Bratster
Re: 121GW no backlight (button?)
« Reply #1 on: September 29, 2018, 11:47:07 pm »
Does your backlight flash on for a second when you turn the meter on?
I know on firmware version 1.26 it does.
Sent from my Fi Moto x4 using Tapatalk
Offline int2str
« Reply #2 on: September 30, 2018, 12:16:35 am »
Nope, just no reaction to holding the button.
Pressing it changes mode, so that works.
Still on FW 1.22. Will try upgrading to the latest.
I know it worked at some point...
Offline int2str
« Reply #3 on: September 30, 2018, 12:22:37 am »
Upgraded to 1.51.
Still no reaction to press+hold on mode key...
Offline int2str
« Reply #4 on: October 01, 2018, 10:45:43 pm »
So, not a common problem then I take it....
Is there a test mode or something in the firmware?
I'm 2 for 2 in  broken EEVBLOG products now :(
Offline Bratster
« Reply #5 on: October 01, 2018, 10:57:59 pm »
if it doesn't blink when you turn the meter on and does not turn on when you push/hold the button for it then it does appear that the backlight is bad.
 You should contact Dave and see what they have to say.
Shit happens.
