Author Topic: An humble request to multimeter manufacturers - modify APO  (Read 2318 times)
Online Neomys Sapiens
Re: An humble request to multimeter manufacturers - modify APO
« Reply #25 on: February 10, 2019, 04:22:55 am »
I wish there was a way to permanently disable it, or set it to disabled in a way that persists until I choose to enable it. It's a bit like those obnoxious start-stop systems so many modern cars use to exploit a loophole in the way emissions are measured. Usually you can disable it when you start the car, but it will enable again the next time you drive it. If I turn something off, I want it to stay off.
That’s how the Keysight meters work.
that's a bit of information which will be considered when getting a handheld DMM again.
