Author Topic: 16 channel digital probe for HP54645D MSO?  (Read 10824 times)
Offline carl_labTopic starter
« on: September 27, 2016, 04:49:48 pm »
Where can I get a 16 channel digital cable and probes for HP54645D MSO for a reasonable price?
Are there clones available?
Can I make one DIY?
« Last Edit: September 27, 2016, 06:54:16 pm by carl_lab »
Offline alank2
Re: 16 channel digital probe for HP54645D MSO?
« Reply #2 on: September 28, 2016, 07:29:29 am »
Thank you!
The cable looks like a normal floppy drive/HD flat cable.
I thought the original was a woven/twisted pair type flat cable? Am I wrong or doesn't it matter?
What do I need for 54645D scope?
Pod 1 Data + J Clock,
Pod 2 Data + K Clock,
Pod 3 Data + L Clock,
Pod 4 Data + M Clock,
Pod 5 Data + N Clock or
Pod 6 Data + P Clock Logic Analyzer Probe?
What's the differences?
Offline alank2
« Reply #3 on: September 28, 2016, 12:02:47 pm »
It is.
You are right; I found this one to work fine, but signal integrity is likely better on the woven/twisted one.
The kit I listed above comes with the Pod 4 Data + M Clock one, but I'm not sure what the differences are.
The following users thanked this post: carl_lab
« Reply #4 on: September 28, 2016, 01:27:55 pm »
...I'm not sure what the differences are.
Maybe just the numbering (for "real" logic analyzers with more than 16 channels)?  :-//
The PCB is just an extension without any components on it?
« Last Edit: September 28, 2016, 01:39:48 pm by carl_lab »
Offline alank2
« Reply #5 on: September 28, 2016, 02:00:10 pm »
That is correct, no components, straight through.
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #6 on: September 28, 2016, 05:06:35 pm »
To be clear: it's not just floppy cable.There's  resistor network in the head (see the teribly bad picture) which makes the input impedance 100k. Otherwise you'd have reflections up the yazoo.
Offline alank2
« Reply #7 on: September 28, 2016, 05:22:09 pm »
Ice-Tea is correct, the HP part of it has a resistor network in it.  The floppy cable and adapter boards however are straight through.
Online Someone
    • send complaints here
« Reply #8 on: September 28, 2016, 10:23:12 pm »
This comes up over and over on the forum, with the same misinformation each time. Agilent produced a lengthy document on the cabling including how to design your own interfaces to it, bizarrely its still on the Agilent site:
http://cp.literature.agilent.com/litweb/pdf/5968-4632E.pdf
The document is "Probing Solutions for Logic Analyzers" should people need to find it in the future.
The following users thanked this post: egonotto, carl_lab
« Reply #9 on: September 29, 2016, 07:21:33 am »
Yes, thank you!
I think, this is what you mean:
« Reply #10 on: September 29, 2016, 07:48:17 am »
What do you think, do I need the original woven ribbon cable?
What about bandwidth?
Could this cable be a reasonable compromise ($1.85/ft = $6.10/m)?
http://www.surplussales.com/wire-cable/ribbon.html
http://www.surplussales.com/wire-cable/pdf/wrc-468-2829-050.pdf
« Last Edit: September 29, 2016, 04:02:43 pm by carl_lab »
Online georgd
  • Country: cs
« Reply #11 on: September 29, 2016, 09:28:43 am »
Patent paper with best description what is it an why need to use:
https://www.google.ch/patents/US4777326
Quote from the patent:
A type of cabling method used in the prior art required the use of a coaxial cable with a resistive center conductor for each signal to be probed. For example, a logic analyzer having 16 probes would require 16 coaxial cables tied together from the logic analyzer to the system under test. This tended to greatly improve the performance of the probing system, since the shielding was greatly improved, bandwidth was increased, and crosstalk was reduced. However, the result was an extremely bulky, costly, and heavy cable, making it difficult for the user to operate with a typical system under test.
On short distances up to 20 cm and on frequencies below 100 MHz an ordinary flat cable should to work.
Georg
Georg
Offline JFJ
« Reply #12 on: September 29, 2016, 11:37:01 am »
The original cable is woven, but its signal and ground conductors are not in twisted pairs. Each signal conductor is separated by two, thinner, ground conductors. This parallel signal/ground conductor arrangement is intended to reduce the capacitive coupling between adjacent channels, to avoid crosstalk. Flat, 80-conductor, Ultra DMA hard drive cables used a similar technique to reduce crosstalk.
A twisted pair cable would be of no benefit, because your scope's digital inputs are single ended (all the signal grounds are common). A differential input would be required to reject the common noise pickup of a twisted pair.
When purchased new, the pod connectors are all the same (unlabeled). A sheet of self adhesive labels is included, so that the user can assign each pod's function.
« Reply #13 on: September 29, 2016, 04:58:24 pm »
Thanks georgd and JFJ.
I think, this is correct, but regardless there are twisted pair P-ATA/UDMA HDD cables:
AFAIK P-ATA/UDMA is single ended, unlike differential SCPI, so why they use twisted pair cable for P-ATA/UDMA then?
« Last Edit: September 29, 2016, 06:04:34 pm by carl_lab »
Offline timb
    • timb.us
« Reply #14 on: September 29, 2016, 05:48:27 pm »
Because, it's easier to route these cables inside a computer case, makes things look overall neater and helps with cooling. This happened in the late-90's/early-2000's.
Originally, 80 conductor (P)ATA-66 cables were flat, just like their slower 40 conductor ATA-33  counterparts. Case modders would take Exacto knives and cut little slits between every few conductors and then zip tie them together. This led to "round" cables being commercially produced; they're not actually twisted pair in the true sense (though the entire bundle may be twisted together).
« Reply #15 on: September 29, 2016, 06:03:53 pm »
I don't think so, this one looks to me like a perfect multiple twisted pair cable.
Each pair of wires is twisted separately, not only the whole bundle...
Anyway, now I don't think twisted pair cable will have any benefit, because the patent paper's sketches show, the special cable is NOT twisted pair.
Another point:
The linked patent paper also says:
"... is constructed from wire and fabric woven together to form a flat ribbon cable, having resistance wires for signals alternating with standard lossless wires for ground to form a lossy transmission line."
But standard ribbon cable uses high conductible copper wire... This will cause reflections as mentioned and reduce bandwidth.
I don't know, if I need the full bandwidth so using a standard cable maybe OK.
Does anybody know, if there will be a signal level problem at lower frequencies, when you use a standard copper ribbon cable instead of the original resistance wire cable?
What is the resistance over one signal wire of the original cable?
« Last Edit: September 29, 2016, 09:33:08 pm by carl_lab »
Offline JFJ
« Reply #16 on: September 30, 2016, 02:19:52 pm »
There's only direct access to signal wires at the probe end of an original cable (the plastic shell at the scope end is riveted). The resistance between scope connector and the other end of one signal wire is 190 ohm:
Another problem with using an 80-conductor PATA cable is that one of signal wires used by the HP54645D, for channel 9 (I think), would be internally shorted to ground, by the connector:
It would probably be easier to modify a used woven cable from a different HP Agilent logic analyzer - e.g. a 16510-61601 or 16510-61602 16-channel cable (they usually sell for a tiny fraction of the price of a used 54620-61601 cable).
« Last Edit: September 30, 2016, 02:24:41 pm by JFJ »
« Reply #17 on: September 30, 2016, 08:52:34 pm »
I tried to make a simulation by LTSpice
a) using a line resistance of 190 Ohms (original cable)
b) using a line resistance of 0 Ohms (standard ribbon cable)
Ri calculation: Ri = (100k+370-90.9k-250-190) Ohm = 9030 Ohm
Ci is roughly estimated 10 pF.
« Last Edit: September 30, 2016, 09:02:23 pm by carl_lab »
« Reply #18 on: September 30, 2016, 09:00:47 pm »
The amplitude response does not look very flat in both diagrams...
I'm sure my model is not absolutely correct (I'm neither a RF specialist nor a LTSpice specialist)...
How can I simulate the distributed resistance and distributed capacitance of the woven special cable more realistic?
« Last Edit: September 30, 2016, 09:16:24 pm by carl_lab »
Offline tautech
« Reply #19 on: September 30, 2016, 11:38:20 pm »
IMO you're over thinking it.
Digital channels probes do not offer the same response and accuracy as a analogue scope probe or need to.
Keep it as simple as possible and give a DIY probe a try.
In a real use situation you're only looking at timing correlations between channels and an indication of amplitude.
Even if decoding waveforms can look gawd awful and the scope will still decode.
Real bus line or logic performance is best left to a normal or active scope probe.
Avid Rabid Hobbyist
The following users thanked this post: carl_lab, genesilvernail
Offline timb
    • timb.us
« Reply #20 on: October 01, 2016, 09:42:36 am »
The particular cable in that picture *may* use twisted pair, but there's no electrical benefit to it, since the signaling isn't differential. The cable in your picture also has a copper-braided shield that doesn't even appear to be connected, so it looks more "X-Treme Modder" BS than just functional.
Like I said, originally we would just take flat 80-conductor ribbon IDE cables and cut slits in the ribboning so it could be zip tied (or heat shrunk) into a bundle. It worked absolutely no differently than the original flat cable. This was commonly done from ATA-66 right up to ATA-133 speeds.
Online Someone
« Reply #21 on: October 01, 2016, 11:13:29 am »
Twisted pair still rejects induced noise and improves crosstalk when used with single ended signalling:
http://www.ti.com/lit/an/snla164/snla164.pdf
« Reply #22 on: October 01, 2016, 02:35:31 pm »
Thanks to all!
I will simply test different types of cable, when I get the oscilloscope and the "HP Pod Data+Clock" module incl. probe leads.
« Last Edit: October 01, 2016, 02:43:29 pm by carl_lab »
Offline scopeman
« Reply #23 on: February 22, 2022, 09:57:13 pm »
I need to make a set of these cables and I ordered a 40 pin woven cable from another logic analyzer.
I have a question about the termination method at the pod end of the cable. Are those wires crimped or are they soldered? My guess is that is resistance wire and that the connection is crimped.
Thank you,
Sam
W3OHM
W3OHM
Offline oPossum
« Reply #24 on: February 22, 2022, 10:15:47 pm »
Soldered to a PCB
The following users thanked this post: DaneLaw
