Author Topic: 16 channel digital probe for HP54645D MSO?  (Read 10948 times)
Offline gslick
Re: 16 channel digital probe for HP54645D MSO?
« Reply #25 on: February 22, 2022, 11:35:46 pm »
I need to make a set of these cables and I ordered a 40 pin woven cable from another logic analyzer.
If you picked up a 40-pin to 40-pin woven cable, part number 01650-61607, as would be used on an HP 1650 series logic analyzer, then just use a common 01650-61608 flying lead set on the POD end of the cable. No assembly required.
Offline scopeman
« Reply #26 on: March 02, 2022, 04:17:10 am »
Thank you for the detailed close up!
Sam
W3OHM
Offline dazz1
« Reply #27 on: August 07, 2023, 08:59:53 am »
Hi
It has been a while since the last post here, but I have just purchased a Hewlett Packard 54645D Mixed Signal Oscilloscope in good condition to add to my ancient and small collection of test equipment.
Now I'd like to get the digital probes for it.  Absolutely no danger of getting a set in my country.    The e-bay prices for the HP 54620-61601 probe set are eye watering.
The HP 16510-6160x  sets are a lot cheaper, but I don't know the pros/cons of these cheaper probes.
What are the current options for making/buying suitable digital probes?
« Last Edit: August 07, 2023, 09:22:53 am by dazz1 »
Dazz
Over Engineering: Why make something simple when you can make it really complicated AND get it to work?
Offline dazz1
« Reply #28 on: August 08, 2023, 12:31:16 am »
Hi
I may have found the answer to my own question.
See this link the the HP Digital Probe Selection Guide
https://www.keysight.com/us/en/assets/7018-06707/data-sheets/5968-4632.pdf.
Dazz
Offline tautech
« Reply #29 on: August 08, 2023, 12:42:00 am »
Hi
Yes, linked in post #8 in this thread.
Did you miss it ?
Avid Rabid Hobbyist
Offline dazz1
« Reply #30 on: August 08, 2023, 04:46:56 am »
Did you miss it ?
When I clicked on the link, I got a DNS error so I had to find the document myself.
I tried attaching the document to my post, but the file size exceeded the limit.
Dazz
Offline dazz1
« Reply #31 on: August 09, 2023, 10:02:31 am »
Hi
I read through the HP Digital probe guide and I did not find it that useful.
I have found that the proper digital pod is   54620-61601  originally made for the 54620 logic analyser.  Very expensive on e-bay.
I did a forum search for HP 54645D and went through all of the postings.    It looks like the cable 16510-61602 is compatible, but I don't know if it comes with the pods to connect the grabbers.
Dazz
Online alm
« Reply #32 on: August 09, 2023, 02:18:11 pm »
No, the cable is just a woven resistive cable similar to the original cable (but connecting to a single 16 channel pod instead of two smaller 8 channel pods). Although of course things may get sold on eBay in all kinds of combinations. The pods used are described on page 47-50 of the document you didn't find useful. Just search for "hp logic analyzer pod" on eBay. Try to find one with all leads and clips included still in its vinyl pouch. The label like pod 1, pod 5 etc doesn't matter, that's just a label.
Offline dazz1
« Reply #33 on: August 09, 2023, 10:15:39 pm »
The problem is that I haven't used a LA since 1986 so I am a little out of date.  Narrowing down the options to pg 47-50 helps a lot.  The table on pg46 only has one dot for 1650 series.
I found a HP reference here https://edadocs.software.keysight.com/kkbopen/what-digital-probe-cables-and-accessories-are-available-for-keysight-mixed-signal-oscilloscopes-msos-589743268.html
It says the 01650-61607 cable was useful but I am not certain if these are all compatible with my HP 54546D scope.
I did try plugging in a standard hard drive cable but the connectors have one pin plugged, so that doesn't work.  I found a seller nbhightech on e-bay that advertises "Agilent HP 10089A Logic Probe with Flying Leads for 54620C".  Sort of a semi DIY solution.  I assume the little pcbs have the passive terminator components.
I have been looking at modules.  The module I have only includes RS232 and parallel port.  Not that useful these days  Ideally I'd like to get the GP-IB & maths module which is desirable but not essential for me.    The e-bay buy-now prices rule out that option.
I have also looked at options to replace the noisy fan.    The 80mm factory fan specs 47cfm which explains why it is so noisy.  A low noise Noctua NF-A8 or NF-R8 could be swapped in but their air flow spec is about half.  I need to do some further investigation before trying that mod.  Maybe I could add some vanes to better guide the air flow over the heat sinks to compensate for the lower gross airflow.  It would be worth it to get rid of the fan noise.
I have spent a little time finding my way around the user interface.  I can understand why these scopes are still so popular.  Very easy to use.
If there are deficiencies, it is decoding serial protocols and no published circuit diagrams.
Dazz
Offline dazz1
« Reply #34 on: August 09, 2023, 10:33:04 pm »
I tried that search and got a lot of hits on pods but no pouches.  I am unsure whether these pods plug straight into the scope, or if there should be a cable between the scope and the pod.   Many listings include references to K,M&N clocks.  I don't know if that is something I need to worry about.
Dazz
Online alm
« Reply #35 on: August 09, 2023, 11:01:32 pm »
The information that's relevant to you is what they call 40-pin connectors. 90-pin connectors was something that came in the early 2000's for their high-end logic analyzers. Also anything about Mictor and other PCB connectors is irrelevant for you, because those are only helpful if you're designing your own boards with them in it.
Search for pictures of either the cable or the end that takes the cable (e.g. HP 1650A/B, 1651A/B, 1652A/B, 1653A/B in the case of 01650-61607, and HP 16510A in the case of the 16510-* cables). It should only have one pod connection (so 16-pins), not two pods as many later cables. And the logic analyzer side should look like an IDE cable (40 pins 0.1"). The pod side always looks like that. If 16510-61602 is compatible, then probably so is 16510-61601 (one is shielded and the other is not shielded). From the pictures it looks like 01650-61607 is shorter, and the 16510 cables seem to have an odd right-angle 40 pin connector, so I'd try to find 01650-61607 if possible.
Not all IDE cables have that pin plugged, and you can remove the pin with a sharp objet. It's generally just press fit. But you might miss on a signal or ground connection, and signal integrity won't be the best without twisting and especially without resistive conductors.
No, you need a cable between the scope and the pod. Ignore the stuff about different clocks, that's only stickers so on logic analyzers with multiple pods you know which pod corresponds to which clock.
As for one with all accessories, see for example this one. Not sure if that's the cheapest price. It might also help to search for HP/Agilent E5383A or 01650-61608. Something like This listing (I have no relation or experience with this seller) might be interesting, since it appears to come with a cable that looks like it might work, although I prefer the latter flat clips to these round clips. You'll have to search for Australian listings on your own, but this might give you an indication on what to search for. Sellers may not always use the correct part numbers since I don't think they are printed on the cables. At least not very obviously. So it might pay to scroll through a bunch of "hp logic analyzer cable" listings.
Offline dazz1
« Reply #36 on: August 10, 2023, 12:55:46 am »
I found that listing by myself, but I had no idea if would be compatible or complete.
It might also help to search for HP/Agilent E5383A or 01650-61608. Something like This listing  might be interesting, since it appears to come with a cable that looks like it might work, although I prefer the latter flat clips to these round clips.
At least it has a pouch  :)
Quote from: alm
I turn on World Wide search on e-bay but almost all hits come from the USA.
I will keep looking and following searches.  I have no urgent need for anything.
Dazz
Offline dazz1
« Reply #37 on: August 10, 2023, 01:03:53 am »
Hi
What about this 01650-61608 :
https://4gte.com/products/hp-agilent-01650-61608-differential-probe-adapter/
Missing the grippers and cable but seems reasonably priced?
Edit:
Looks like 61608 are actually for differential probes.  Probably not what I need.
« Last Edit: August 10, 2023, 01:12:04 am by dazz1 »
Dazz
Online alm
« Reply #38 on: August 10, 2023, 07:51:33 am »
No, it's not differential. That's an error by 4gte. They didn't have differential pods in the 1650 era. See the 90 pins section of the probing for logic analyzers document for part numbers of differential probes and what they look like.
The clips are standard though finding 20 good quality ones might not be any cheaper than buying a complete set. Make sure you get all leads and at least a couple ground leads.
Offline dazz1
« Reply #39 on: August 10, 2023, 08:17:20 am »
It seems that error spread because I found a couple of references to differential probes with that part number.  That sort of error makes it a lot more difficult for me to identify what I need and whether it will work.
I am learning far more about probes than I ever wanted too.
Quote from: alm
Shipping anything across the USA border is expensive so it make sense for me to buy a complete set as one package rather than multiple purchases.    It also makes sense to maximise $/kg because shipping is a dead cost.  For that reason I am better to buy the more expensive GPIB/FFT/Memory module than the cheaper GPIB module.   At least that is the excuse I tell my wife. ;)
What would be really useful is a website app that shows what part is compatible with any other part.
I can see that I will just need to be patient.
Dazz
Offline dazz1
« Reply #40 on: August 10, 2023, 10:48:59 am »
You are definitely right.
I found some info on the 01650-61608 at this link (which focuses on the 60pin to 40pin cable):
https://www.techtravels.org/2022/11/agilent-logic-analyzer-cable-teardown-photos/
So if I got a full pod set including grippers etc, I would only need the 40pin cable to connect to my scope, I think
Dazz
Offline dazz1
« Reply #41 on: August 11, 2023, 10:47:55 am »
Hi
OK so clearly patience is not a virtue I possess.   I have purchased the e-bay lead set, complete with pouch.
It should include the cable, pod, grounding leads and round style TH grippers.
https://www.ebay.com/itm/274747226156
and I also purchased 15 of the rectangular type grippers
https://www.ebay.com/itm/126008291238
I am hoping the combination of the pod HP 01650-61608  plus the cable will be more versatile than the one piece HP 54620-61601 cable/pod made for my scope, and vastly cheaper.
Specifically, the cable sans-pod gives the option of making custom probes, using another style of pod, or plugging into a connector on a pcb (for designed-in probing).
The lead set comes with the round style grippers, but I think it is worth the cost of buying the smd grippers as well.
The cost of the lead set plus extra grippers gives me another capability at a relatively low price.    It will take a month or two for delivery so I will let you know if I wasted my $$$ then.
I am going to sell my serial/parallel module and watch & wait for a GPIB/math/memory module.
Dazz
