Author Topic: Voltcraft DSO-1084E (Hantek DSO-4xx4B/C) stop on boot screen, Warning - bad CRC  (Read 1955 times)
Offline kukenTopic starter
Hello. I bought Voltcraft DSO-1084E (Hantek DSO-4084B / C) and it stops on boot screen. I attached a serial adapter and captured the terminal during boot. Can anyone help what to do now, how to get it back to life  :(
OM*** Warning - bad CRC, using default environment
##### EmbedSky BIOS for SKY2416/TQ2416 #####
This Board: SDRAM is 64MB; Press Space key to Download Mode.!
NAND read: device 0 offset 0x380000, size 0x800
 2048 bytes read: OK
**************************normal start*******************************
NAND erase: device 0 offset 0x380000, size 0x80000
Erasing at 0x380000 --  25% complete.
Erasing at 0x3a0000 --  50% complete.
Erasing at 0x3c0000 --  75% complete.
Erasing at 0x3e0000 -- 100% complete.
OK
NAND write: device 0 offset 0x380000, size 0x800
Writing data at 0x380000 --   0% complete.
Writing data at 0x380800 -- 100% complete.
 2048 bytes written: OK
 2048 bytes read: OK
Saving Environment to NAND...
Erasing Nand...
Warning: Erase size 0x00004000 smaller than one erase block 0x00020000
         Erasing 0x00020000 instead
Erasing at 0x80000 -- 100% complete.
Writing to Nand... done
NAND read: device 0 offset 0x400000, size 0x400000
 4194304 bytes read: OK
Boot with zImage
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.2.35 (root@zgt) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-176) ) #22 PREEMPT Fri Oct 27 02:56:10 CST 2017
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: SMDK2416
Ignoring unrecognised tag 0x54410008
Memory policy: ECC disabled, Data cache writeback
CPU S3C2416/S3C2450 (id 0x32450003)
S3C24XX Clocks, Copyright 2004 Simtec Electronics
CPU: MPLL on 800.000 MHz, cpu 400.000 MHz, mem 133.333 MHz, pclk 66.666 MHz
CPU: EPLL on 96.000 MHz, usb-bus 48.000 MHz
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: noinitrd ubi.mtd=5 ubi.mtd=6 root=ubi0:rootfs rootfstype=ubifs init=/linuxrc console=ttySAC0 lcd=X480Y272
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 58948k/58948k available, 6588k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xc4800000 - 0xf6000000   ( 792 MB)
    lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc03fc000   (4048 kB)
      .init : 0xc03fc000 - 0xc041b000   ( 124 kB)
      .data : 0xc041c000 - 0xc05b5200   (1637 kB)
       .bss : 0xc05b5224 - 0xc05d2fdc   ( 120 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:107
irq: clearing subpending status 00000002
Calibrating delay loop... 198.45 BogoMIPS (lpj=496128)
pid_max: default: 4096 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
S3C2416: Initializing architecture
S3C2416: IRQ Support
S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics
DMA channel 0 at c4804000, irq 88
DMA channel 1 at c4804100, irq 89
DMA channel 2 at c4804200, irq 90
DMA channel 3 at c4804300, irq 91
DMA channel 4 at c4804400, irq 92
DMA channel 5 at c4804500, irq 93
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
s3c-i2c s3c2410-i2c: slave address 0x10
s3c-i2c s3c2410-i2c: bus frequency set to 9 KHz
s3c-i2c s3c2410-i2c: i2c-0: S3C I2C adapter
Advanced Linux Sound Architecture Driver Version 1.0.24.
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
s3c-adc s3c24xx-adc: attached adc driver
msgmni has been set to 115
io scheduler noop registered (default)
io scheduler cfq registered
s3c-fb s3c-fb: window 0: fb
s3c-fb s3c-fb: LCD type is TN83 800*480, default_bpp=16, pixclock=5
s3c-fb s3c-fb: window 1: fb
s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440
console [ttySAC0] enabled
s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440
s3c2440-uart.3: ttySAC3 at MMIO 0x5000c000 (irq = 94) is a S3C2440
loop: module loaded
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
info->cpu_type=3, tacls_max=8
s3c24xx-nand s3c2416-nand: Tacls=3, 22ns Twrph0=7 52ns, Twrph1=3 22ns
s3c24xx-nand s3c2416-nand: System booted from NAND
s3c24xx-nand s3c2416-nand: NAND ECC disabled
NAND device: Manufacturer ID: 0xc8, Chip ID: 0xd1 (Unknown NAND 128MiB 3,3V 8-bit)
NAND_ECC_NONE selected by board driver. This is not recommended!
Scanning device for bad blocks
Bad eraseblock 376 at 0x000002f00000
Creating 9 MTD partitions on "NAND":
0x000000000000-0x000000100000 : "uboot"
0x000000100000-0x000000180000 : "params"
0x000000180000-0x000000380000 : "logo"
0x000000380000-0x000000400000 : "misc"
0x000000400000-0x000000800000 : "kernel"
0x000000800000-0x000003a00000 : "rootfs"
0x000003a00000-0x000004e00000 : "config"
0x000004e00000-0x000005200000 : "kernel_bk"
0x000005200000-0x000008000000 : "recover"
UBI: attaching mtd5 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: max. sequence number:       1386
UBI: attached mtd5 to ubi0
UBI: MTD device name:            "rootfs"
UBI: MTD device size:            50 MiB
UBI: number of good PEBs:        399
UBI: number of bad PEBs:         1
UBI: number of corrupted PEBs:   0
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             0
UBI: total number of reserved PEBs: 399
UBI: number of PEBs reserved for bad PEB handling: 3
UBI: max/mean erase counter: 8/3
UBI: image sequence number:  0
UBI: background thread "ubi_bgt0d" started, PID 341
UBI: attaching mtd6 to ubi1
UBI: max. sequence number:       1291
UBI: attached mtd6 to ubi1
UBI: MTD device name:            "config"
UBI: MTD device size:            20 MiB
UBI: number of good PEBs:        160
UBI: number of bad PEBs:         0
UBI: total number of reserved PEBs: 160
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 10/8
UBI: background thread "ubi_bgt1d" started, PID 344
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usbcore: registered new interface driver usblp
usbcore: registered new interface driver uas
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
samsung-ts s3c2416-ts: driver attached, registering input device
input: S3C24XX TouchScreen as /devices/virtual/input/input0
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq disabled
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
s3c-sdhci s3c-sdhci.1: clock source 0: hsmmc (133333333 Hz)
s3c-sdhci s3c-sdhci.1: clock source 1: hsmmc (133333333 Hz)
s3c-sdhci s3c-sdhci.1: clock source 2: hsmmc-if (24000000 Hz)
mmc0: SDHCI controller on samsung-hsmmc [s3c-sdhci.1] using ADMA
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
S3C24XX_UDA134X SoC Audio driver
S3C24XX_UDA134X SoC Audio: l3 data pin already in use
s3c24xx_uda134x: probe of s3c24xx_uda134x.0 failed with error -16
ALSA device list:
  No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
Registering the dns_resolver key type
s3c-rtc s3c2410-rtc: setting system clock to 2019-08-24 13:08:30 UTC (1566652110)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size:   48377856 bytes (47244 KiB, 46 MiB, 381 LEBs)
UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format:       w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:10.
Freeing init memory: 124K
UBIFS: mounted UBI device 1, volume 0, name "config"
UBIFS: file system size:   18157568 bytes (17732 KiB, 17 MiB, 143 LEBs)
Please press Enter to activate this console. dso-iobank: install ok
0x603
gpio_major_n = 6, io_minor_n = 3, output 0
0x408
gpio_major_n = 4, io_minor_n = 8, output 1
AFG3050 fpga configure init
adc init
TQ2416 ADC driver
tq2416_backlight_init_timer0:0x200, 0x2
bkl tq2416-backlight initialized done...
dso-buzzer s3c2416-beep initialized done...
user file is /lib/firmware/dso4000.bit
nstatus0 :0x0
nstatus1 :0x1
fpga state :0x1
file len is 460418
FPGA CONFIGURE DATA DOWN finish.0x1, 0
FPGA CONFIGURE ok.
fpga bank 11811
input: dso_kbd as /devices/virtual/misc/dso-fpga/input1
dso-fpga: install ok
make snd node.
dm9000 Ethernet Driver, V1.31
dm9000 dm9000: read wrong id 0x2b2a2928
dm9000 dm9000: wrong id: 0x2b2a2928
dm9000 dm9000: not found (-19).
ifconfig: SIOCSIFADDR: No such device
Erasing 128 Kibyte @ 0 -  0% complete.
Erasing 128 Kibyte @ 20000 - 25% complete.
Erasing 128 Kibyte @ 40000 - 50% complete.
Erasing 128 Kibyte @ 60000 - 75% complete.
Erasing 128 Kibyte @ 80000 - 100% complete.
start
reg is 0x2, val is 0x1
reg is 0x2, val is 0x3
reg is 0x3, val is 0x0
reg is 0x4, val is 0x39
reg is 0x7, val is 0x3f
reg is 0x8, val is 0x8
reg is 0x9, val is 0x80
reg is 0xd, val is 0x8
reg is 0xf, val is 0x1b
reg is 0x10, val is 0x20
reg is 0x11, val is 0x5c
reg is 0x12, val is 0x40
reg is 0x13, val is 0x2a
reg is 0x14, val is 0x11
reg is 0x15, val is 0x11
reg is 0x16, val is 0xe0
reg is 0x17, val is 0x8
reg is 0x19, val is 0x1f
reg is 0x1a, val is 0x8
reg is 0x1b, val is 0x23
reg is 0x1c, val is 0x20
reg is 0x1d, val is 0x20
reg is 0x1f, val is 0x28
reg is 0x20, val is 0x80
reg is 0x21, val is 0x12
reg is 0x22, val is 0x58
reg is 0x23, val is 0x74
reg is 0x25, val is 0x1
reg is 0x26, val is 0x4
reg is 0x37, val is 0x20
reg is 0x39, val is 0x20
reg is 0x3b, val is 0x20
reg is 0x41, val is 0x9a
reg is 0x4d, val is 0x3
reg is 0x4e, val is 0x50
reg is 0x4f, val is 0xda
reg is 0x50, val is 0x74
reg is 0x51, val is 0x4b
reg is 0x52, val is 0x12
reg is 0x53, val is 0x13
reg is 0x55, val is 0xe5
reg is 0x5e, val is 0x80
reg is 0x69, val is 0x64
reg is 0x77, val is 0x3
reg is 0x7d, val is 0x62
reg is 0x4, val is 0x38
reg is 0x6, val is 0x71
reg is 0x6, val is 0x70
reg is 0x2, val is 0x2
reg is 0x4, val is 0x0
fpga_ctl_kbd_open:1:  (null)
fpga_ctl_kbd_open:2:c3b49260
open kbd dso_kbd successful
dbus is valid and addr is unix:path=/tmp/dbus-V5w2Gxfefl,guid=df4b3265ba0504a9bee7b4405d6136d1
system info do begin
init system info ...
read_sytem_infos_from_file:1:80M$DSO1084E
read_sytem_infos_from_file:2:DSO1084E,80M
init system info over
system info do end
anolis_init:machine is 80M
anolis_init:after adjust intensity
anolis_init:over
fpga_init:0x4003f000
pll is locked
gpio_major_n = 0, io_minor_n = 2, output 0
gpio_major_n = 0, io_minor_n = 3, output 0
gpio_major_n = 0, io_minor_n = 4, output 0
gpio_major_n = 0, io_minor_n = 8, output 0
gpio_major_n = 10, io_minor_n = 12, output 1
util_helper_load_setup:6, 0
init_calibration_result: in:/config/root/cali.dat
init_calibration_result:1:12345678, 12345678
init_calibration_result:2:101, 101
init_calibration_result:3:89abcdef, 89abcdef
init_calibration_result: has calibration result
measure_helper_set_one_chn_all_only:0
acq_dot_nm_of_timerange =4000,time_range=1600000000000,dso_acq.dot_factor =1,sample_rate =2500.000000
dso_acq_control:1:2056, 2056,109
dso_acq_control:2:2165, 1947
dso_acq_control:3:108250000, 98150000
dso_acq_control:4:after= 108250000, before= 98150000
[root@Hantek ~]#
Offline W1ZZT3XX
Hey.
Did You get it back to life?
Otherwise: What was the last thing You changed?
I would try to update the device with the latest update file, get it from Voltcraft or just take the Hantek one, because it should not make a difference, at least not after changing the device's vendor in the system.inf.
You can also follow the thread https://www.eevblog.com/forum/testgear/upgrading-the-hantek-dso4072c-osciloscope-bandwidth-from-70mhz-to-200mhz/25/ as I pusblished a hacking manual there.
Your log output looks normal so far but misses the last anolis entries.
Offline kosomsk
  • Country: ru
« Last Edit: October 08, 2019, 10:45:19 am by kosomsk »
