Author Topic: 16GHz Tek DSA71604C. What were they thinking?  (Read 2644 times)
Offline Jwalling
  • This is work?
« on: September 25, 2019, 02:45:14 pm »
This is the acquisition board in a Tek 16GHz DSA71604C. There are two conductive foam assemblies and each surround 4 chips. They are crumbling into dust (Conductive dust, mind you!) and there's black dust all over the board. They have the consistency of burnt toast. I can literally crumble them with my fingers! This can't be good.
Shown is the bottom sheet metal with arrows showing where they are located.
WTF is this supposed to accomplish? Does it perhaps help to channel air into the heatsinks?
Then there's this rubber bumper that presses down on the reference TCO. Well, at one time it was a rubber bumper. Now it has the consistency of a melted marshmallow - sticky and quite gooey. I can't imagine what this was supposed to accomplish...
Jay
System error. Strike any user to continue.
The following users thanked this post: TiN, MadTux
Offline capt bullshot
Re: 16GHz Tek DSA71604C. What were they thinking?
« Reply #1 on: September 25, 2019, 04:38:06 pm »
Conductive foam might be used to dampen RF leaking from the traces.
Offline DaJMasta
    • medpants.com
« Reply #2 on: September 25, 2019, 05:00:54 pm »
Maybe they're trying to use the foam as some kind of gasket to force air through those central heatsinks?
Whatever the reason.... it seems like the wrong choice, though  |O
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: September 25, 2019, 05:17:46 pm »
Lecroy older WaveMaster / WavePro DSO also have this foamy thing and mine also start to disintegrate upon touching, so i dont touch them too much. i didnt check whether they are conductive or not. they are directly under the ventilation hole from PC area where user can open and got exposed. so i guess they are there to avoid dust, debris or worst metalic items such as screws from falling and shorting whats under there or changing rf characteristic thereof. under is just some relays and coax cable  :-//
It's extremely difficult to start life.. one features of nature.. physical laws are mathematical theory of great beauty... You may wonder Why? our knowledge shows that nature is so constructed. We simply have to accept it. One could describe the situation by saying that... (Paul Dirac)
Online edpalmer42
« Reply #4 on: September 25, 2019, 08:44:16 pm »
The only time I've seen rubber bumpers used like that was to ensure that the circuit board couldn't flex enough to cause a short to whatever was beside it (e.g. the case or another board).
Ed
Offline technogeeky
  • Older New "New Player" Player Playa'
« Reply #5 on: September 26, 2019, 01:55:26 am »
I think we can logically deduce that since this foam is conductive (intentionally), then it's not for airflow reasons. We might be able to further deduce that it's there for RF reasons, but I'm not sure.
Could the goop on the TCXO be both calibration blocking and (thermal) mass loading? Maybe if you take a TCXO and make it much more dense and massive, its thermal fluctuations will be dampened and therefore its properties will be improved?
I'd love to hear expert opinion on this.
I feel like it's still in the realm of possibility that everything (except perhaps conducive dusting) is in the realm of normal behavior?
Offline tautech
« Reply #6 on: September 26, 2019, 02:09:04 am »
Any of the ESD safe foam sheets should work for this and what you have left over you can store your IC's in.
https://nz.rs-online.com/web/c/safety-security-esd-control-clean-room/esd-control-clean-room/esd-safe-foam-film-wrap/?searchTerm=conductive%20foam
Avid Rabid Hobbyist
The following users thanked this post: MadTux
Offline Someone
« Reply #7 on: September 26, 2019, 03:19:21 am »
Looks and sounds a lot like dissipative foam RF absorber material. Its nasty stuff so they must have included it for a good reason.
Offline KE5FX
    • KE5FX.COM
« Reply #8 on: September 26, 2019, 06:14:30 am »
Crosstalk between those huge differential pair traces would be my guess.  If those aren't routed with care, they won't be quite as "differential" as the designer hoped.
It would have been a bad day in Beaverton when whatever prompted that foam to be added was discovered.  That much, you can bet on.
The goop on the TCXO might have been applied to keep air currents away from it, including convection currents from the surrounding PCB itself.  Pretty standard stuff there.  I guess it doesn't cover the whole thing, so maybe just covering the trimmer would have been enough.
The following users thanked this post: Jwalling
Offline JimS
« Reply #9 on: September 26, 2019, 09:12:49 am »
Looks like the foam would direct air from the fans to flow under the foam then up through the seat sink fins.
I saw something similar to the dissolving bumper on a Fluke 5725A.
That bumper was to keep a metal part from contacting a PCB.
Offline Jwalling
  • This is work?
« Reply #10 on: October 01, 2019, 05:35:46 pm »
The reason I'm messing around with this. One of my customers sent this to me for repair.
Symptoms: Unit would power on for a few seconds, then shut down.
There's a lot of reasons why this can happen. The power interconnect that contains a bunch of DC/DC converters has an Atmel 8 bit RISC processor that monitors all voltages including the ones on the ACQ board. It also monitors that all the fans are running.
All the DC/DC converters in the scope are powered by a 48VDC 25A 1200W Emerson power supply.
After mucking around with this scope for a few days, I finally found the culprit. There is a short on -5VDC rail somewhere on the acquisition board.  A 100uF ceramic cap that is soldered on top of another cap. I removed the one next to it to get the value using my Fluke 289 DMM.
For now I've removed the cap and the scope is running. It throws errors, but this is likely due to the RF coaxial relays/attenuators being removed.
Some more pics of the solder side this time, along with the shorted cap and more gooey stuff. There's also a picture of what's left of the conductive foam. Not much... I'm not sure whether I should replace it...  :-//
Each channel of the scope is powered by its own 1.8V 40A buck power supply. Pretty impressive. Not sure what -5V powers... A/D converters, possibly.
I don't think there's anything too critical about a replacement cap, but thoughts are welcome!
Jay
Offline nctnico
« Reply #11 on: October 01, 2019, 05:38:19 pm »
I'd take the cap next to it from the board and measure that one.
Offline DaJMasta
    • medpants.com
« Reply #12 on: October 01, 2019, 05:39:18 pm »
That goop looks quite unappetizing, but a board that size full of ADCs is a sight to behold.  :-+
The following users thanked this post: Kilrah
Offline Jwalling
  • This is work?
« Reply #13 on: October 01, 2019, 05:42:13 pm »
Err... That's what I said above.  ;)
Jay
Offline Kilrah
« Reply #14 on: October 01, 2019, 05:42:46 pm »
That board is insane... and a 1200W PSU for a scope, and 70W/channel?  :o
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #15 on: October 01, 2019, 05:49:48 pm »
As far as the foam goes, I'd be inclined to replace it.  I don't think manufacturers like Tek are inclined to put things like that in unless there's a very good reason for doing so.
-Pat
Offline Jwalling
  • This is work?
« Reply #16 on: October 01, 2019, 05:51:13 pm »
I'm leaning toward this one.
https://www.digikey.com/product-detail/en/kemet/C1210C107M8PACTU/399-11631-1-ND/4918887
10V X5R which is twice the rail voltage.
Still guessing about the foam. To foam or not to foam...
It sits at least 2cm off the board so could this still be a case for RF shielding? And if I don't use conductive foam, should I use something else?
The 6 exhaust fans blow outward, pulling cool air through the bottom cut-outs shown in my first post. Kind of makes my think that the foam is used to force air through the fins on the chips...
EDIT: Didn't know this stuff is so expensive.
https://www.digikey.com/products/en/rf-if-and-rfid/rfi-and-emi-shielding-and-absorbing-materials/869?k=conductive+foam&k=&pkeyword=conductive+foam&sv=0&sf=0&FV=ffe00365&quantity=&ColumnSort=0&page=1&stock=1&pageSize=25
Granted it's 2' x 2'.
« Last Edit: October 01, 2019, 06:05:44 pm by Jwalling »
Jay
Offline Someone
« Reply #17 on: October 01, 2019, 10:45:19 pm »
Its an absorber, usually for suppressing crosstalk in RF systems.
Offline thm_w
« Reply #18 on: October 02, 2019, 01:06:49 am »
I'm sure that would be fine.
Although its 66% down at 5V, so for future reference, this one for example would be equivalent (~33uF): https://www.digikey.com/product-detail/en/taiyo-yuden/EMK325BJ476MM-P/587-5436-1-ND/7067112
Offline EEVblog
« Reply #19 on: October 02, 2019, 01:28:38 am »
What age are we talking about here?
Offline EEEnthusiast
  • Country: in
  • RF boards, Precision Analog, Carpentry
    • https://www.zscircuits.in/
« Reply #20 on: October 02, 2019, 02:49:17 am »
Yes, adding thermal mass on a TCXO is a good method to improve its stability. However, in this case, it looks like some kind of tape which will not add much thermal mass. However, it can prevent gusts of air from cooling the TCXO rapidly. This it can help reduce the temp drift.
Making products for IOT
  • Country: in
« Reply #21 on: October 02, 2019, 02:51:53 am »
The high speed ADCs are suckers for power. They draw in couple of Amps when running at 3Gsps. So this one would have at least 6 of them per channel. Now multiply that with the number of channels and you have some black hole for current.
Offline TiN
  • xDevs.com/live - 24/7 lab feed
    • xDevs.com
« Reply #22 on: October 02, 2019, 05:14:36 am »
Circa 2010.
YouTube | Metrology IRC Chat room | Live-cam | Share T&M documentation? Upload! No MB limit, firmwares, photos.
Offline Jwalling
  • This is work?
« Reply #23 on: October 02, 2019, 09:05:14 am »
Circa 2010.
I'd say you're dead-on if that's a date code. 31st week of 2010.
Jay
Offline Jwalling
  • This is work?
« Reply #24 on: October 02, 2019, 09:15:01 am »
Some more pics, now with the attenuators in place. (even they have heat sinks!)
The rectangular foam still in place is flexible, they must have used a different type of material for them.
Scope is pretty well optioned.
CH4 seems a bit noisy, but I'm running it without two of the 100uF caps which I will order today along with the arm and a leg foam.
SPC was last run in May of 2019 where it was passing.
Jay
