Author Topic: Siglent SDG1025 weird behaviour  (Read 1097 times)
Offline VanitarNordic
« on: May 09, 2018, 11:22:00 am »
I have a brand new Siglent SDG1025 function generator. I put both channels on the pulse section and tried to generate pulses. Then I modified the Delay for the second channel to make some shifts in the second channel signal. I did not work at all. I changed to a different waveform such as the square and I modified the phase section. it did not shift again!
Then I thought that might be because of the calibration or something because I had not performed that. Then I went to Utility menu and did the self-calibration. But now the situation got worse. Now the output voltages are not normal and all are wrong. it gives wrong outputs.
« Last Edit: May 10, 2018, 03:10:55 am by VanitarNordic »
Offline tautech
Re: Siglent SDG1025 weird behaviour
« Reply #1 on: May 09, 2018, 09:06:26 pm »
I don't know what should I do with the damn thing  >:(
Sorry I haven't got one anymore to help work through all your issues but I doubt there's anything wrong except user error.
WRT the output voltages.
If the output is set for fifty ohms and not loaded by that impedance the p-p will read high.
Set the output for HiZ.
Avid Rabid Hobbyist
The following users thanked this post: VanitarNordic
Offline nctnico
« Reply #2 on: May 09, 2018, 09:39:38 pm »
Phase shifting should work even without coupling the channels together but the frequencies will have to be exactly the same. Any screendump from an oscilloscope showing the signals?
Offline Macbeth
« Reply #3 on: May 09, 2018, 09:44:11 pm »
I have an SDG1025 and a scope I have just been using today, but OP's post is extremely vague and so I have no interest in helping them.
« Reply #4 on: May 10, 2018, 03:16:23 am »
It is already on HiZ. Your doubt is wrong that just happened after calibration
« Reply #5 on: May 10, 2018, 03:21:17 am »
I will appreciate if you leave us alone then and dont write a post
« Reply #6 on: May 10, 2018, 03:24:03 am »
Please dont reply to this post. I will contact the manufacturer for help
Offline tautech
« Reply #7 on: May 10, 2018, 03:43:26 am »
Can I ask what firmware version is installed ?
The latest is 39R5 and available here:
https://www.siglenteu.com/service-and-support/firmware-software/waveform-generators/#sdg1000-series
Avid Rabid Hobbyist
« Reply #8 on: May 10, 2018, 03:45:50 am »
Yes thank you, but I have done that already and calibrated with the latest firmware. I forgot to mention in the first topic
Offline tautech
« Reply #9 on: May 10, 2018, 09:57:55 am »
Have you checked out the operating tips on the Siglent websites ?
https://www.siglenteu.com/operating-tip/generating-multi-phase-waveforms/
Avid Rabid Hobbyist
« Reply #10 on: May 10, 2018, 10:14:53 am »
That's for when we want to generate 4 signals using two generator devices. I am just using two channels or even one. The device usage is quite straighforward. I contacted the manufacturer and the seller. Waiting for a response
