Author Topic: 1x, 10x, 100x Scope Probe ITSELF quality/safety??  (Read 571 times)
Offline GlennSprigg
  • Medically retired Tech. Old School / re-learning !
« on: April 04, 2020, 12:54:33 pm »
Firstly, this is not a re-run of the 2014 post in this forum about measuring 240v A/C on a scope!!  I understand about the scopes limitations, and the applied voltages peak-to-peak values, where 100x would be better than 10x etc. etc. I'm asking about the PROBES themselves!  :)
I use/have only switchable probes, (1x & 10x), and if one is measuring say up to 50v using a 10x probe then that's all sweet!  But just as Dave knocks cheap <$20 Multimeters, (rightly so!), when measuring say 240v to 500v as there is little protection, and the Meter may end up like "a Dingo's guts" etc., I can't help thinking about the PROBES internals as well, as this is rarely mentioned?   :(
If you have say 200v to 500v, (and not a low-power signal!), would/could cheaper probes break down internally, destroying not only the Probe itself, but then what it may pass on to the actual Scope too!!  I've never looked inside such Probes to see what they do??
AS A BIG SIDE NOTE !!  hahaha...
A "Mr Carlson's Lab" video from 2018, was discussing a very old 1930 'National' Oscilloscope. I couldn't believe the absolutely minimalist circuitry, and lack of components!!  Vertical scaling/voltage? no problem!! Hard wired input straight to the vertical deflection plate? Horizontal Oscillator not even a sawtooth, but deflectors almost directly connected to a low voltage A/C tap on the main transformer!   Wow!!  Check out the Schematic below, starting at 26:44 in the video...   8)
« Last Edit: April 04, 2020, 01:28:24 pm by gnif »
Offline GlennSprigg
Re: 1x, 10x, 100x Scope Probe ITSELF quality/safety??
« Reply #1 on: April 04, 2020, 01:34:33 pm »
Hmmm.  I posted this accidentally in 'TestGear', but meant to post it in 'GeneralChat'.
I moved it, but was moved back(?) by gnif. I had a reason for wanting it in 'General'  :)
Online blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #2 on: April 04, 2020, 01:44:15 pm »
Probes are generally rated at very low CAT ratings. If a 100x probe is rated 1kV, chances are that is CAT I 1kv, meaning no overvoltage protection capability at all.
If you tap a CAT II 240V circuit, under the slightest chance, it can blow up. FYI, CAT II 300V class is rated for up to 2.5kV transient.
Also, always RTFM when probing high voltage. Probes have maximum capacitance dissipation limit, and their marketing material might not be accurate.
For instance, Keysight 10076C (my usual choice for single ended HV probing) is marketed as a 4kV probe, but it is only rated for 3.7kVpk, and CAT II 1kVpk.
At DC, it withstands up to 3.7kVpk, and at 1MHz, it withstands only 1kVpk. This is a thermal limit, and if you only view a few pulses, you can ignore it (AFAIK, and AFAID).
When in doubt, go with a differential probe. If you have loads of money, go for an isolated probe or isolated scope or at least a portable floating scope.
And lastly, stay away from Keysight U1600 series. The isolation is only galvanic for LF, and for HF is uses differential caps, making it horribly unreliable for measuring high dv/dt signals.
« Last Edit: April 04, 2020, 01:57:42 pm by blueskull »
The following users thanked this post: GlennSprigg
Offline Grandchuck
« Reply #3 on: April 04, 2020, 01:46:34 pm »
This reminds me of an oscilloscope built by my father in the early 1950's.  It used a motor, loudspeaker and a light source.  Similar to this:  https://youtu.be/oeGdQRQBeiw
He used a 16 mm movie projector for the light source.
Offline 2N3055
  • Country: hr
« Reply #4 on: April 04, 2020, 01:58:44 pm »
You should read "ABC of probes" by Tektronix, and also "Tektronix Oscilloscope Probe Circuits Concepts".
Offline vk6zgo
« Reply #5 on: April 04, 2020, 02:27:26 pm »
There are high voltages & high voltages!
At about 2:30 in the morning, we were trying to find out where the drive signal from the previous stage prior to the PA had disappeared to on a MF AM Broadcast transmitter.
I reasoned that, if I wound the RF drive right back, I should be able to see the drive at the grid connection to the PA, using a 'scope & a x10 probe.
Setting it up, I turned the Tx on,
"Kerblam!"& the transmitter shut down!
Opened the cabinet, & everything past the finger guard on the probe had vaporised.
Oops!----- maybe winding the RF drive "right back"didn't quite do what I thought!
Doh!
In fairness, though, we both had finished a normal full days work, driven 300+ km, & it was 2:30am ("Stupid O'clock", as another workmate called it).
With great trepidation, I approached the input circuitry of the 'scope (a Tek 453 from memory) only to find no damage------ The probe had "given its all " & protected the 'scope!
Re the sidenote:-
I remember many years back, the old Perth Tech College had an "open day"where they had a lot of weird stuff up & running, one of which was a "homebrew" version of just such an Oscilloscope, built in a perspex box, so you could see the guts.
(Now that was a real "Tech School", with lots of real stuff--not like this "TAFE" nonsense!)
My 1976 ARRL Handbook has a schematic & a description of the same sort of device. although it wasn't presented as a "project".
Apparently, the idea is that the mid portion of a sine wave is "quasi-linear", so it can be used for horizontal deflection.
« Last Edit: April 04, 2020, 02:29:35 pm by vk6zgo »
Online rstofer
« Reply #6 on: April 04, 2020, 03:54:18 pm »
A scope was in the ARRL Handbook far earlier than that!  I built such a scope somewhere around 1958 (could have been a couple of years later, give or take) and it was a terrific project for a kid.
Offline joeqsmith
« Reply #7 on: April 04, 2020, 06:07:52 pm »
I had posted the internals of a very low cost 100X probe.  You may find that here:  https://youtu.be/v1jJ1Z_fgFU?t=518    I'm not sure what "not low-power" means.  I'm not aware of any of these smaller probes having any sort of safety rating.  I doubt you will find safety rating on some of the larger probes you would typically use for electronics.
Quote from: rstofer link=topic=7=236122.msg2998752#msg2998752 date=1586010446
[/quote]
Enjoy some old pictures....
« Last Edit: April 04, 2020, 06:10:13 pm by joeqsmith »
How electrically robust is your meter?? https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Offline tggzzz
« Reply #8 on: April 04, 2020, 08:37:49 pm »
Always look at how a probe's maximum voltage depends on frequency. Get it wrong and the probe melts :)
Offline GlennSprigg
« Reply #9 on: April 05, 2020, 06:47:54 am »
Have now downloaded both those, as .PDF documents. Thanks !!  :-+
