I realize this is an old thread. But for kicks was looking at fixed x1 probes on Digikey. Cal Test makes a couple
ge2501, 1.2m, 45pF, 55 MHz
ge2502, 2m, 65pF, 35 MHz
I believe the capacitances assume scope input is 1MOhm//13pF, so the 13pF is included in those numbers. They each run about $30. I realize that circuit loading could of course be an issue with these, but I’m tempted to try one out. Anyone have experience with them?
Jason
Update: picked up the ge2501 in my last digikey order. Using a tinySA transmitter, 50 Ohm pass-through and the supplied probe-tip-to-BNC adapter, I find that I get about 35 MHz 3-dB bandwidth. At 55 MHz it was more like 6 dB down. This was measured by my Picoscope 5244B 200 MHz scope with nominal 1 M Ohm||13 pF input - just what the probe was designed for. I like the probe but it will have niche uses.
