Heres a mini review of this Power Supply.
Power supply has the following taps:
0-7v
8-14v
15-21v
22-31v
The goods:
1 ) Disables the output when you press any "Memory" button. i.e M1, M2, M3 etc
*To get into M5, Press the M4 button and turn the "ADJUST" knob right. Funky huh?
2 ) OCP OVP Can be set to protect your board incase the power supply goes boom.
* To set OCP OVP just set your voltage and current. With output off press the OCP and/or OVP button(s) to turn them on.
3 ) The BEEP is still makes a dying bird sounds and can be turned off by holding the OCP button until it makes a BEEEEP sound.
4 ) The output will refuse to turn on if the voltage or current is set above the stored OCP OVP voltages and current. (very handy)
5 ) Store up to 5* Memory Voltage and Current settings.
*The fifth one is annoying to get to.
6 ) Big beefy* mains power button that actually switches the mains primary.
*Looks not rated for 3 amps, but it works and its still working.
7 ) CHEAP very CHEAP (as in priced low, build quality not bad.) Got mines for $50 USD NEW shipped.
8 ) You can lock all soft buttons on the keyboard with the LOCK button.
9 ) Theres a thermistor on the series pass transistor heatsink. I presume it will turn the unit off if it goes over temp?
And the Bads:
1) LOUD FAN. Korad, you don't need the fan to be spinning at 3000 rpm idle. Full load sounds like a jet engine. (At least it uses a standard 2 pin 12v 80mm fan. Just replace it.)
2) Very confusing users manual, no where does it say how to set a OCP OVP.
3) Makes a BOING sounds when turning on by the Mains power button.
4) The transformer is very hot, you will need to mess with the airflow a bit to get air to pass next to the transformer. (on Daves unit, it has a piece of steel bent down to force air pass the transformer.
5) Non switchable transformer primary, mines seems to be stuck on 220v. (SRA-SOLDER sells a switchable 110-220v one, not sure if this is a different generation)
6) Fan is controlled by current output not temperature. It has a thermistor, why not use it?
7) When on M4. Any movement on the "ADJUST" knob will move it to M5 and switch the output off. VERY annoying
The voltages and current readings are nearly spot on. The binding posts feels very solid. Does get a little hot to the touch on the rear of the unit but not burning.
Check out the pictures. Can someone tell if those Rubycons are real? The print on them looks high quality, they are quite cold (114F) after operating at high loads for a period of time.
FAKE RUBYCON CAPS. Expected....
------Original Post------
Hey everyone!
I just purchased a Korad KA3005D here in china for $50USD NEW, but all they had was 220v 50hz. I have a 110v to 220v transformer at home
http://www.ebay.com/itm/Goldsource-STU-300-W-Watt-Step-Up-Down-110V-220V-Voltage-Converter-Transformer-/160733095687?pt=BI_Circuit_Breakers_Transformers&hash=item256c706707and i was wondering if the 60Hz of the 110v mains will interfere with the normal operation of the 220v 50Hz input of the power supply. Is this whole setup correct?
And how should i fully test a new lab power supply?
Jason
