Well, sounds like you are making some headway. Here is a link to a DIY MOSFET tester. Can put it together for a couple bucks, apparently works quite well. Interesting about the gate resistors
http://www.electronicrepairguide.com/test-mosfets.htmlHave heard conflicting statements on whether calibration is required after a power supply swap/repair. most say no unless the 10v reference was way out. You am need to perform some of the calibration for the CRT and DAC, but pretty sure that is not stored in the EEPROM.
Which programmer did you get?. The TL866CS? I managed to get a free sample of the Dallas, $25.00 bucks save there.
Recapped a working 2465A power supply and can not get it to work, Either something wrong in my repair or the new components have caused a aging part to eventually fail. Working through the flowcharts in the manual, frustrating, but at the same time challenging. Appears to be a issue with the inverter.
What is the MOSFETs you have in your power supply. the ones in mine are not what is spec'd in the manual. I am wondering if they had been replaced previosuly. They were IRF820's
