Products => Test Equipment => Topic started by: JuanPC on July 16, 2013, 03:27:19 am
Title: 2ch 200MHz 2GSa/s Scopes....
Post by: JuanPC on July 16, 2013, 03:27:19 am
Just for fun, having 2nd thoughts about spending $$$ on a Bad Ass Scope...
Owon
http://www.owon.co.uk/ (http://www.owon.co.uk/)
Rigol Ds2202
http://www.tequipment.net/RigolDS2202.html (http://www.tequipment.net/RigolDS2202.html)
Instek GDS-2202A
http://www.tequipment.net/InstekGDS-2202A.html (http://www.tequipment.net/InstekGDS-2202A.html)
BK Precision 2556
http://www.tequipment.net/BK2556.html (http://www.tequipment.net/BK2556.html)
UNI-T UTD-4202C
http://uni-trend.com/UTD4202C.html (http://uni-trend.com/UTD4202C.html)
Siglent CFL Series
http://www.siglent.com/en/product/detail.aspx?id=100000004399111&nodecode=119008001 (http://www.siglent.com/en/product/detail.aspx?id=100000004399111&nodecode=119008001)
http://www.testequipmentconnection.com/63043/Siglent_SDS1202CFL.php (http://www.testequipmentconnection.com/63043/Siglent_SDS1202CFL.php)
Agilent DSOX2022A
http://www.testequity.com/products/3676/ (http://www.testequity.com/products/3676/)
http://www.metrictest.com/product_info.jsp?mfgmdl=HP%20DSOX2022A(N) (http://www.metrictest.com/product_info.jsp?mfgmdl=HP%20DSOX2022A(N))
http://www.newark.com/agilent-technologies/dsox2022a/dsox-series-oscilloscope-200mhz/dp/21T9319 (http://www.newark.com/agilent-technologies/dsox2022a/dsox-series-oscilloscope-200mhz/dp/21T9319)
Rohde&Schwarz HAMEG HMO2022
http://www.hameg.com/0.616.0.html (http://www.hameg.com/0.616.0.html)
http://www.hameg.com/fileadmin/user_upload/downloads/dblatt/HAMEG_Overview_HMO_HOO_EN.pdf (http://www.hameg.com/fileadmin/user_upload/downloads/dblatt/HAMEG_Overview_HMO_HOO_EN.pdf)
http://webstore.rohde-schwarz.com/us/hamegr-hmo2022.html (http://webstore.rohde-schwarz.com/us/hamegr-hmo2022.html)
Tektronix DPO2022B & TDS2022C
http://www.tek.com/oscilloscope/mso2000-dpo2000 (http://www.tek.com/oscilloscope/mso2000-dpo2000)
http://www.tek.com/oscilloscope/tds2000-digital-storage-oscilloscope (http://www.tek.com/oscilloscope/tds2000-digital-storage-oscilloscope)
http://www.tequipment.net/TektronixDPO2022B.html (http://www.tequipment.net/TektronixDPO2022B.html)
http://www.tequipment.net/TektronixTDS2022C.asp (http://www.tequipment.net/TektronixTDS2022C.asp)
LeCroy WaveAce 222
http://www.mouser.com/ProductDetail/Teledyne-LeCroy/WaveAce-222/?qs=sGAEpiMZZMvAbnEMxb34PUlbC4fWX7u7 (http://www.mouser.com/ProductDetail/Teledyne-LeCroy/WaveAce-222/?qs=sGAEpiMZZMvAbnEMxb34PUlbC4fWX7u7)
http://www.amazon.com/LeCroy-WaveAce-222-Oscilloscope-Interleaved/dp/B0094JXAMI (http://www.amazon.com/LeCroy-WaveAce-222-Oscilloscope-Interleaved/dp/B0094JXAMI)
LeCroy WaveJet 322A
http://www.digikey.com/product-detail/es/WAVEJET%20322-A/WAVEJET%20322-A-ND/2796140 (http://www.digikey.com/product-detail/es/WAVEJET%20322-A/WAVEJET%20322-A-ND/2796140)
http://www.mouser.com/ProductDetail/Teledyne-LeCroy/WaveJet-322-A/?qs=sGAEpiMZZMvAbnEMxb34Pc8raUQOiYb7 (http://www.mouser.com/ProductDetail/Teledyne-LeCroy/WaveJet-322-A/?qs=sGAEpiMZZMvAbnEMxb34Pc8raUQOiYb7)
http://www.amazon.com/LeCroy-WaveJet-322A-Oscilloscope-Interleaved/dp/B0094JXGI6 (http://www.amazon.com/LeCroy-WaveJet-322A-Oscilloscope-Interleaved/dp/B0094JXGI6)
Advantages/Disadvantages:
Rigol
DS2202
UltraVision
50,000 wfs/s
14Mpts, Optional Memory up to 56Mpts.
500uV/div to 10V/div
2ns/div to 1000s/div
8 inch TFT (800x480) WVGA
CAT I 300 Vrms, CAT II 100 Vrms
3.9 kg
$1626.usd.
Instek
GDS-2202A
VPO (Visual Persistence Oscilloscope),
80,000 wfm/s
2Mega Point Memory Depth for Half-channel,
Segmented Memory.
1mV /div~10V/div
1ns/div to 100s/div
8 inch 800*600 High Res TFT LCD Display
easy conversion from a DSO into a MSO
3MHz option DDS generator: Sine, Triangle and Square.
optional LAN/SVGA Interface module and GPIB interface module.
300V (DC+AC Peak), CAT I
4.2kg
$1382usd.
Owon
MSO8202T
7.8 inch color LCD display (8") TFT screen, 640×480 pixels.
2mV/div-10V/div
1ns/div-100s/div steps 1-2-5
6000 points on each channel.
Record length: 2M for Oscilloscope, 4M for LA
16 optional logic inputs
http://shop.owon.co.uk/mso8202t-18-p.asp (http://shop.owon.co.uk/mso8202t-18-p.asp)
£895.
€1,034.62
Owon
SDS8202
1ns/div-100s/div, step by 1-2-5
8-inch color TFT LCD, 800x600 pixels
Record length: 10M points per channel
http://www.shop.owon.co.uk/sds-8202-22-p.asp (http://www.shop.owon.co.uk/sds-8202-22-p.asp)
£625.
€722.50
BK Precision 2556
1M & 50ohm input coupling
Certificate of Calibration
2mV/div-10V/div (1-2-5 order)
2.5ns/div–50s/div
7 in. Color TFT, 480 x 234 resolution, 64K color.
24 kpts.
400V (DC+AC PK-PK, 1 Mohm input impedance, X10) CAT I,
5Vrms (50ohm input impedance)
Approx. 9.5 lbs (4.3 kg)
$1515usd.
UNI-T
UTD-4202C
2mV ~ 5V/div
1024k
5.7 inches
Logic Analyzer
Current-to-Voltage Convertor module
13.7kg?
$1190usd.
Siglent
SDS1202CFL
24Kpts
7’’color TFT-LCD 480 horizontal by 234 vertical pixels, 64K color, 150:1, 300nit
2.5KG
1M 13pF, 50ohm
1.0nS/DIV - 50S/DIV / 2.5ns/div-50s/div
2mV-5V/div(1-2-5 order)
±400V(DC+ACPk-Pk), CAT I, CAT II
Alternative Trigger
4.3kg-4.5kg
$1795usd.
Agilent
DSOX2022A
InfiniiVision
50,000 waveforms/s
100 kpts
2 mV/div to 5 V/div** ** 2 mV/div is a magnification of 4 mV/div setting. For vertical accuracy calculations, use full scale of 32 mV for 2 mV/div sensitivity setting.?
2 ns/div to 50 s/div
8.5-inch WVGA 800(H)x480(V) pixel with 64 levels of intensity grading?
300 Vrms, 400 Vpk, more with other probes.
25 ppm ±5 ppm per year (aging)
Capture glitch as narrow as 500 ps at all timebase settings
12 bits when ? 20 ?s/div
Averaging from 2 to 65,536
Option WaveGen 20MHz Sine, 10MMHz SQR, 100khz ramp/triangle +$511usd.
Option Segmented Memory +$307usd.
Option Mask limit testing +$307usd.
Option 8-ch MSO $731usd.
Option 1M Memory Upgrade $200usd.
Option Educators Kit +$511usd.
Option LAN/VGA module, +$404usd. GPIB module +$511usd., *Only one module may be used at a time.
Option 3-Digit Volt Meter +$76usd.
Option Automotive Serial Triggering and Analysis +$500usd.
Option advanced FFT frequency domain analysis Visualizer (ASV) Software $500usd.
built-in storage compartment
3.85kg-4.08kg
$2,215usd.
Rohde&Schwarz HAMEG
HMO2022
2,000 wfs/s
1 Mohm/50ohm
1 mV/div....10 V/div.
200 Vpk @ 1M
2 MPts.
6.5 inch 640x480
Option 8-ch Mixed Signal 1 GSa/s, 1 MPts.
2.5 kg
$2,660usd.
Tektronix
TDS2022C
2 GS/s Sample Rate on both Channels.
10X oversampling on all channels,
2.5k point Record Length on both Channels.
2 mV to 5 V/div.
2.5 ns to 50 s/div
5.7 in. (144 mm) Active TFT Color Display, Unkown Resolution.
300 VRMS CAT II; derated at 20 dB/decade above 100 kHz to 13 Vp-p AC at 3 MHz
Lifetime Warranty *1 Limitations apply.
2kg.
$1870usd.
Tektronix
DPO2022B
Digital Phosphor Oscilloscope Technology "real-time intensity grading"
1 GS/s Sample Rate on All Channels.
1 Megapoint Record Length on All Channels
5,000 wfm/s Maximum Waveform Capture Rate.
2 mV/div to 5 V/div
2 ns to 100 s
300 VRMS with peaks ? ±450 V
7 in. (180 mm) Widescreen TFT-LCD Color Display, 480 horizontal × 234 vertical pixels (WQVGA).
Option Serial Triggering and Analysis
Five-year warranty
3.6kg.
$2280usd.
LeCroy
WaveAce 222
9 kpts/Ch
5.7” Color, 320x240
2 mV/div–5 V/div
2.5 ns/div–50 s/div
1 MOhm–400 V Pk, 5 Vrms (50 Ohm)
2.3kg.
$2100usd.
LeCroy
WaveJet 322A
3600 wfms/s with Replay
7.5" Color flat-panel TFT-LCD, 640 x 480 VGA
500 kpts/Ch (all channels)
500us at 1GS/s, 250us at 2GS/s.
2GS/s interleaved (single-shot)
2 mV/div–10 V/div
2 ns/div–50 s/div
400V CAT I
10 ppm (typical)
3.2kg
$4050usd.
Agilent & Rigol have the same Screen Resolution, Agilent .5" bigger 800x480.
Siglent CFL, BK Precision 2556 & Tek DPO2022B have similar or the same 7" screen 480x234 resolution, 64K Color Display.
Owon SDS8202 & Instek GDS2202A have same 8" 800x600 Display resolution.
UNI-T UTD-4202C & LeCroy WaveAce 221 have the smallest 5.7" screen size, LeCroy 222 has 320x240, the Uni-T is Unknown, but probably the same.
Owon MSO 7.8" 640×480 pixels, has a 3rd Place in this shotout, LeCroy 322A, Hameg same resolution, but LeCroy has 7.5" and R&S Hameg has 6.5".
Both Rigol & Agilent have the same wfm/s 50.000 ("2nd place")
Instek has 1st Place true >80.000wfm/s.
Tektronik DPO has 3rd Place, LeCroy WaveJet 322A has 4th Place, and R&S Hameg the 5th Place.
According to Dave Owon SDS Review, the SDS9302 has 35wfm/s, Uni-T, Siglent CFL & BK Precision are Unknown...
Rigol has most sensittive Vertical/div .5mV, Instek has 2nd Place 1mV, most others have 2mV "3rd Place."***
Instek has Segmented Memory, Agilent is optional +$307usd.
Higher Price seems directly proportional to a lower/stable ppm.
Rigol has the 1st Place in Memory, Owon SDS8202 2nd Place, Owon MSO8202T 3rd Place, Instek, Tek DPO, R&S Hameg share 4th place with 2Mpoints/channel, Uni-T 5th place if web specifications are right*, Agilent 6th place* but can be upgraded to a 5th place 1M memory +$200usd, LeCroy 322A has 5th place 500kpoints/ch, Siglent & BK Precision sharing the 6th Place 24Kpts, LeCroy WaveAce222 9kpts has 7th place, Tek TDS 2.5k has the last Place.
Question is: Segmented Memore could rival Rigols Big Memory?
Memory is that important?
When Memory becomes important?
Memory vs. wfm/s ? wfm/s wins most of the times.
Less Buggy software/Firmware?
Agilent, Instek, Tek DPO & Rigol have some kind of Analog Intensity Graded Display, Owon maybe, the others are unknown,
Title: Re: 2ch 200MHz 2GSa/s Scopes....
Post by: cthree on July 16, 2013, 03:56:50 am
There you go then. That's a pretty comprehensive rundown.
Post by: rf-loop on July 16, 2013, 08:14:11 am
You find Siglent price perhaps from one of worlds most expensive place.
(without EU taxes etc)
SDS1202CFL is more like well under 1k$ and note (look carefully if BK model is different or not technically - who made it?)
SDS1204CFL is 4 channel and also its price is around 1k$
SDS1304CFL is 4 channel 300MHz model and even it can normally buy under 1.5k$
With 1795USD price  you can buy bundled SDS1202CFL + SDG5000
With 4 channel models you get 2 full 2GSa/s channels if only 2 channel is in use.
For 2 channel models one channel in use 2GSa/s and with 2 channel in use 1GSa/s per channel.
CFL models have LAN as default.
Post by: DaveW on July 16, 2013, 09:12:59 pm
Just as I've got one in front of me,
