Author Topic: 3.5kV power supply teardown  (Read 13225 times)
Offline Lodoiska
Re: 3.5kV power supply teardown
« Reply #25 on: April 23, 2018, 12:24:10 pm »
Hi!
If you woudn't mind, I would greatly appreciate it!!
Thank you so much.
Safe travels,
Lodo
Offline Diplomata
  • Country: pt
« Reply #26 on: October 12, 2018, 03:13:03 pm »
Hello
Do you know who the manufacturer of the power supply enclosure is?
Or does anyone know who is the manufacturer of Pharmacia AKTA system housings?
I can only realize that they are made of cast aluminum / magnesium ...
And it should be a northern European manufacturer, since it was of Swedish construction. Thank you.
Best regards
Carlos Barata
Offline coromonadalix
« Reply #27 on: October 12, 2018, 10:46:17 pm »
They are beautiful :)  drool
Offline klim
« Reply #28 on: June 15, 2020, 08:14:40 am »
Hi, could you please upload a picture from your plug connectors for this device, i'll get mine next week, but also without any connection plugs, so i need to make my own.
Offline HighVoltage
« Reply #29 on: September 12, 2020, 04:44:05 pm »
Just saw your post now...
First I used self constructed 2mm connectors.
But at the end I did not like them too much.
Then I rebuilt the connector completely for 4mm banana plugs
For up to 1000 Volts I am using the MC insulated cables.
For 1000 to 3500 Volts I am using my self made 20.000 Volts cables to 4 mm banana plugs.
Here are some pictures of my setup.
The following users thanked this post: coromonadalix
