Author Topic: 3.5mm VNA calibration kit price comparison  (Read 1070 times)
Offline 小太Topic starter
« on: February 12, 2024, 10:49:22 am »
While thinking about getting the SMA calibration kits (US$600~700) mentioned in this thread, I started wondering what 3.5mm kits cost.
It turns out there's way more selection in 3.5mm kits, so I made a table comparing the prices I found after a brief search on the internet. Maybe this will be useful for other people so sharing it here :)
Notes:
 - 3.5mm or 2.92mm kits only. Generally 2.92mm kits aren't included here unless they're relatively cheap
 - SOLT/SOLR kits only. Kits must either contain a "Thru" or have one as an option
 - Must contain calibration coefficients (e.g., C0/C1/C2/C3), whether on the datasheet, printed, or on a USB stick
 - Separate male or female kits don't contain a torque wrench, while "both" kits (containing both male and female parts) include a torque wrench, unless specified otherwise
 - Italic-typed brands are generally considered "famous" or "premium" brands
 - Ordered roughly by price, low to high
BrandFrequencyMale
$USD
Female
$USD
Both
$USD
Notes
Racomtech9 GHzEUC900-3.5mmM
$593
EUC900-3.5mmF
$593
No "both" kit, but ~$100 discount if male+female are bought together
With AU$1=US$0.651
Pico Technology8.5 GHzTA346
$859
TA347
$859
Saluki9 GHzSCKCL09-3.5(M8)
$870
SCKCL09-3.5(F8)
$870
SCKCL09-3.5
$2880
"Both" kit includes N-3.5mm adapters
26 GHzSCK0YTL26-3.5
$1020
SCKCL26-3.5
$3456
40 GHzSCK0YTL40-2.92
$1068
SCKCL40-2.92
$3600
Spanawave26.5 GHzCK520A
$1730
CK521A
$1730
CK052D
$3400
"Both" kit does not contain a torque wrench
40 GHzCK562A
$2490
CK561A
$2490
CK056K02
$4850
Siglent4.5 GHzF603ME
$449
F603FE
$449
9 GHzF604MS
$1855
F604FS
$1855
F604TS
$3695
27 GHzF606MS
F606FS
F606TS
$4770
Maury Microwave26.5 GHz8050CK41
$5453
Rosenberger26.5 GHz03S30R-MSOTS3
$1700
03K30R-MSOTS3
$1700
03CK010-150
$6417
Copper Mountain9 GHzS911T
$1245
26.5 GHzS2611
$2195
40 GHzT4311
$2745
Fairview Microwave8.5 GHzFMCK1001
$4400
Unclear if calibration coefficients are included
26.5 GHzFMCK1013
$2420
FMCK1012
$4940
FMCK1000
$6840
"Both" kit unclear if calibration coefficients are included
Anritsu20 GHzTOSLK50A-20
$2395
TOSLKF50A-20
$2510
26.5 GHz3650A
$7410
Includes pin gauge and extra thrus/adapters
Keysight9 GHz85033E/100/200
$6219
26.5 GHz85520A
$4099
85521A
$4099
85052D
$9967
Rohde & Schwarz24 GHzZV-Z235
$11115
26.5 GHzZN-Z135
$3130
ZN-Z135
Honourable mention goes to this Taobao 达睿康 85033E female-only clone (though brass male versions are available) which has been previously reported to be a pretty good match to the 85033D coefficients.
It doesn't include a Thru (just like the 85033E without options), but at just US$153 (¥1100) it's too good to not mention
Feel free to reply with corrections or additions, and I'll update the table when I spot them
« Last Edit: February 13, 2024, 11:04:33 am by 小太 »
The following users thanked this post: Construct, NF6X, TheSteve, mankan
Offline switchabl
Re: 3.5mm VNA calibration kit price comparison
« Reply #1 on: February 12, 2024, 10:03:30 pm »
Both the Spanawave and the R&S ZN-Z135 are almost certainly made by Rosenberger. Spinner is another OEM that makes cal kits for big brands like R&S (https://products.spinner-group.com/rf/test-measurement/vna-test-measurement/compact-calibration-kits).
I would definitely consider Maury Microwave an "A-brand". They used to make the HP cal kits.
CM also sells what look like rebranded Rosenberger and Spinner cal kits (https://coppermountaintech.com/calibration-kits/), might be worth comparing prices.
Note that the specs vary a lot for some of the options on your list, in particular the loads. An extreme example is the Picotech which is only >26 dB @ f>3GHz. They claim >43 dB "corrected", so presumably this is supposed to be used with data based calibration. If you are not using one of their VNAs, you need to make sure yours actually supports that and that you can get the calibration data in a suitable format.
« Last Edit: February 12, 2024, 10:05:03 pm by switchabl »
Offline tautech
« Reply #2 on: February 13, 2024, 12:15:15 am »
None of the cheaper 4.5 GHz Cal kits listed ?
https://siglentna.com/products/accessories/vna-calibration-kits/
Avid Rabid Hobbyist
« Reply #3 on: February 13, 2024, 11:09:39 am »
Sadly, I couldn't find any prices online, and I'm not about to ask them for a quote when I have no interest in buying at present.
But if anyone has gotten a quote for them (with a date), reply with them here and I'll add them to the table :)
Added
Added
Offline Construct
« Reply #4 on: February 23, 2024, 08:32:45 pm »
This is a great table. Thanks for taking the time to put it together.
Online G0HZU
« Reply #5 on: February 23, 2024, 09:14:34 pm »
Is the list confined to just mechanical kits? If not, there are also 3.5mm Ecal kits from various manufacturers.
I've got the old N4431B-60006 3.5mm cal kit here from Agilent for example.
https://www.keysight.com/gb/en/product/N4431B/rf-electronic-calibration-module-ecal-9-khz-13-5-ghz-4-port.html
This was very expensive when new but I think that Keysight are now producing lower cost Ecal kits.
« Reply #6 on: February 23, 2024, 09:42:04 pm »
Aren't ECals specific to a certain brand/series, so (for example) you can't use a Keysight ECal on an Anritsu VNA? Which would make a price comparison table for them moot, since you'll be locked into the same brand anyways...
Online G0HZU
« Reply #7 on: February 23, 2024, 10:08:48 pm »
Yes, generally speaking I think the ecal modules are only meant to be used with the same brand of VNA.
However, not in all cases though... I think some of the Siglent VNAs support Ecal modules from various manufacturers for example. I've not used a Siglent VNA so I haven't tried this myself.
Offline tautech
« Reply #8 on: February 24, 2024, 10:11:36 am »
Just checked SVA and SNA models, both support Ecal kits however neither specify which brand so maybe only the Siglent Ecal modules.  :-//
A total of 36 Cal kits are supported by SNA5000A, Siglent, R&S and HPAK while there are just 3 HPAK Cal kits by SVA1000X models in addition to the Siglent Cal kits.
Ecal is auto identified when connected so if from another brand would need to tested to check if they could work.
SEM5000A Series Electronic Calibration(ECal) Modules:
https://int.siglent.com/u_file/download/23_12_27/SEM5000A_datasheet_DS60050_E01A.pdf
Siglent Cal kits:
https://int.siglent.com/u_file/download/23_08_30/Mechanical%20Calibration%20Kit%20Datasheet_EN01A%20.pdf
Avid Rabid Hobbyist
The following users thanked this post: G0HZU
Offline charliedelta
« Reply #9 on: February 24, 2024, 10:34:02 am »
What about
https://www.kirkbymicrowave.co.uk/
He has the most affordable verifiable VNA cal kits available.
Offline switchabl
« Reply #10 on: February 24, 2024, 11:31:44 am »
AFAIK he doesn't offer a 3.5mm version.
Online G0HZU
« Reply #11 on: February 24, 2024, 12:22:59 pm »
https://www.siglenteu.com/vector-network-analyzer/sna5000a-series/
Compatible with several manufacturers ECal kits (contact us for more information)
This implies the SNA5000A series will support Ecal modules from 'several' other manufacturers. Has anyone here tried and proved this?
Offline switchabl
« Reply #12 on: February 24, 2024, 12:50:09 pm »
I think Shahriar from the Signal Path used a Keysight ECal in his review of the SNA5000A.
