Author Topic: Does the bandwidth limiter work on a hacked Rigol DS2072A?  (Read 2237 times)
Offline nbritton
« on: September 19, 2015, 02:42:08 am »
Does the 100 MHz bandwidth limiter work on a DS2072A that has been unlocked to 200 or 300 MHz?
Offline tautech
Re: Does the bandwidth limiter work on a hacked Rigol DS2072A?
« Reply #1 on: September 19, 2015, 02:55:45 am »
What makes you suspect it wouldn't?
An even higher BW DSO might also have additional BW limit options.
Avid Rabid Hobbyist
Offline nbritton
« Reply #2 on: September 19, 2015, 03:03:57 am »
Because the DS2072A leaves the factory as a 70 MHz scope.
Offline poida_pie
« Reply #3 on: September 19, 2015, 03:06:50 am »
on my hacked to 200MHz DS2072  (not A) with the trigger out fed into ch1 with 50 ohm termination I get
no BW  - 1.52ns rise time
100MHz BW limit - 3.2ns
20 MHz BW limit - 16.2ns
So I can say the BW limit works for me.
Offline tautech
« Reply #4 on: September 19, 2015, 03:08:24 am »
And why wouldn't it have the industry standard 20 MHz BW limit?
Avid Rabid Hobbyist
Offline tautech
« Reply #5 on: September 19, 2015, 03:14:51 am »
Sounds right.  :-+
Avid Rabid Hobbyist
Offline dadler
« Reply #6 on: September 19, 2015, 03:57:53 am »
"Hacked" is no different from unlocked-with-purchased-code in this context. The scope doesn't know it is "hacked". A code is simply entered, and the scope enables the options just as if they had been purchased.
And the BW limit works properly on my DS2072A.
