Does anyone have any recommendations for manufacturers or models of 4 quadrant 3/1 phase AC+DC power supplies? I am interested primarily in models of 10 kVA and below (probably 5 kVA or lower) with +/-300V or higher output voltage. This will primarily be used for testing power electronics, both DC/DC converter and inverters/active rectifiers.
What I have run across so far are Kepco (linear and switch mode) and Chroma Regenerative Grid Simulator Model 61800 (The smallest is 30 kVA so larger than I need).
