I recently bought a miniVNA Pro that I'm using with the provided vna/J software. My main use is looking at SWR, impedance, etc on ham antennas, transmission lines and impedance matching devices.
One of the main things I'd like to do is to set it up to do real-time measurement at a single frequency as the circuit is changed. For example, watch how SWR changes as a variable capacitor in an LC tuning circuit attached to an antenna is turned. I'm running into two issues. First, the software seems to want a frequency range as opposed to a single test frequency. Second, when it's runs repeated scans there's a nontrivial delay (usually of a couple to a few seconds) as the scan is completed. So it's slow-going to tweak and watch how the result changes.
Is there a way to do what I'd like to do? Or is this maybe not the instrument to use for this?
