After repairing my old 465M, I got a bunch of spares that I can give away. Conditions are unknown for the most part unless noticed otherwise. If you are in the bay area, I can arrange for you to pick up from my home. If shipping is involved, I will use FedEx or USPS with tracking and charge actual costs.
1. Main board with Power supply complete. Has a good HV transformer but U 550 block is defective.
2. Main board minus U 550 block and HV transformer.
3. Vertical module-CH 1, knob missing and outer pot shaft broken.
4. Time base-known to be faulty.
5. Case with handle and inside shield complete.
If interested, please PM for info. I will be away from 22nd Oct. to the 6th Nov.
Vertical Module is taken.
I also have 2 CRTs for this same scope.
Thanks.
Vertical Module has been taken. Other parts are still available.
IIRC the CRT will work in a 465B too, I think it's what the tube in mine came from. The CRTs are probably the most useful parts.
Thanks, James. There are also rare components in the timebase modules. I have no way of checking them. Also, I do not want to keep these if it can be used by someone else.
All parts are gone to a good home.
