Hi everyone,
I'm working on project for information cluster. After one of the last EMI test we got report that when they turned on 310MHz@30V/m one of the internal monitoring systems kicked in.
That means that we have problem with the communication buses or some external IC is failing.
The problem is that the lab is in Germany and I'm in Bulgaria, and on top of that, we don't have any recorded logs and the next test is after 4 weeks.
Now my idea is to make some improvised EMI chamber, where I can test the device.
Does someone have experience in building one of these ?
I tried with one clock generator 10~250MHz, but I don't think, that I will be able to get the desired power output without any termination and proper antenna.
The "antenna" was directly next to the board, but the device was working fine.
p.p.
I was following Dave's videos for quite long time, but now I'm happy that I finally joined the forum.
