Author Topic: 50 pounds DMM from Russia  (Read 1236 times)
Offline 001
  • Country: aq
« on: June 23, 2018, 12:10:53 pm »
I found this on the ad site
The DMM that weighs 50 pounds  :-DD :-DD :-DD :-DD :-DD
« Last Edit: June 23, 2018, 12:13:52 pm by 001 »
Offline wraper
  • Country: lv
Re: 50 pounds DMM from Russia
« Reply #1 on: June 23, 2018, 12:32:39 pm »
You're wrong, it weights only 9kg = 20lb
Online Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #2 on: June 24, 2018, 03:15:50 am »
Here's one that weighs 48 lbs (22 kilos), and measures DC Voltage...
Oh, and frequency, too, to either 300kHz or 1.2MHz, depending on options.
 :D
If you want to measure AC or resistance, that's another box, nearly the same size as the meter (meter is 19 x 7 x 18-3/8"; same height and width but only 17-1/4" deep for the AC/Ohms unit) that's a svelte 43 lbs (19.4 kg) that plugs into it.
You've gotta love old test gear!!   :-+ :-+
-Pat
The following users thanked this post: edavid, 001, radiolistener
Offline radiolistener
  • Country: ua
« Reply #3 on: June 24, 2018, 05:12:32 am »
So warm and beautiful digits...  ::)
Offline TimFox
« Reply #4 on: June 24, 2018, 02:02:25 pm »
Dymec was Hewlett-Packard's brand for industrial automation-type stuff.  Note that if you turn "-dy-" 180 degrees, it reads "-hp-".
The following users thanked this post: eKretz, 001, gnavigator1007, WhichEnt2, radiolistener
