Author Topic: Fluke 279 FC  (Read 10347 times)
Offline d3javuTopic starter
  • Country: my
Fluke 279 FC
« on: April 27, 2016, 01:47:24 pm »
Noticed that search on the forum did not return any result for new fluke 279 fc multimeter. What do you guys think about multimeter with built in thermal imaging? The release date is 9th May 2016.
Weblink: Fluke 279FC
« Last Edit: April 27, 2016, 01:49:59 pm by d3javu »
The following users thanked this post: Marco1971
Offline Martini
Re: Fluke 279 FC
« Reply #1 on: April 27, 2016, 02:31:13 pm »
Combining two tools into one is smart if there is some sort of synergy between them. In this case, I'm not convinced it will be the case. How cheaper it is compared to a thermal camera + a DMM ?
Offline mettlerr
  • Country: jp
  • Simplify!
Re: Fluke 279 FC
« Reply #2 on: April 27, 2016, 02:54:14 pm »
I think it depends for whom. But I guess the battery life will be awful.  ::)
  • Country: my
Re: Fluke 279 FC
« Reply #3 on: April 27, 2016, 02:59:30 pm »
No proper pricing available yet but quickly look through few websites found the device listed between 999-1.2k usd.
Offline retiredcaps
Re: Fluke 279 FC
« Reply #4 on: April 27, 2016, 04:20:43 pm »
Martin mentioned this meter in his latest "T4D" Tip for the Day ...
Offline ben_r_
  • A Real Nowhere Man
Re: Fluke 279 FC
« Reply #5 on: April 27, 2016, 05:55:26 pm »
Wouldnt be of any use to me, but maybe someone out there would like both in one unit. Also depends on the price too I suppose.
If at first you don't succeed, redefine success!
Offline zaoka
Re: Fluke 279 FC
« Reply #6 on: April 28, 2016, 12:25:04 am »
Guess who will be first to copy this idea of IR camera and DMM? I bet Keysight...
What you guys think?
Offline Muttley Snickers
  • Cursed: 679 times
Re: Fluke 279 FC
« Reply #7 on: April 28, 2016, 01:42:51 am »
It would be handy if it could take a selfie of the dude that picked it up and walked away with it whilst you had your back turned for a second and then send the image to your smartphone, this is always a concern for us on larger sites.
I haven't looked at all the specifications as yet and a decent thermal camera is on my list of things to get but it wont be one of these, indications are a ten hour battery life according to the link below.
Oritech Australia
http://www.oritech.com.au/FLUKE_dash_279FC_dash_IFLEX/Fluke-279FC-Wireless-TRMS-Thermal-Multimeter-With-iFlex-Current-Probe/pd.php
The following users thanked this post: Monittosan
Offline Fsck
  • sleep deprived
Re: Fluke 279 FC
« Reply #8 on: April 28, 2016, 01:50:42 am »
without being able to use both at the same time... seems like a useless proposition.
no direct physical current measurement seems like a silly decision as well.
this is probably more like a thermal camera with some dmm features added on.
"This is a one line proof...if we start sufficiently far to the left."
Offline blacksheeplogic
Re: Fluke 279 FC
« Reply #9 on: April 28, 2016, 04:32:25 am »
After my experience with the Fluke 233 I've crossed any Fluke product with wireless off my shopping list for that reason. A meter which needs to constantly be feed new batteries is a expensive and a PITA.
Offline kaz911
Re: Fluke 279 FC
« Reply #10 on: April 28, 2016, 12:56:27 pm »
Just get a batterizer?  :-DD - and to be honest maybe the ONLY application where you would get a real benefit... (Fluke 287/289 does not like rechargeable batteries very much - plug fresh ones in - and right there it thinks it is at 1/2 power)
/rant on
anyway - I think if they put some effort in to Fluke Connect to make up for what Fluke 287/289 can't do - that would be nice. But now Fluke Connect is as useless as a meat freezer on the moon. It might work "fine" for FMS work where you go around and log the occasional value here and there and need to document you did it. But the ADMIN alone to use it is bonkers.
So a 289 is great - but while long term logging - it does not show a graph. The FC would be great for that - if just it could maintain the connection and remember back - and have an AUTOSCALING graph and not only that "ticker tape" view. But neither Fluke or Tektronix are not really good at writing any kind of software that does not run inside their instruments.
So please Fluke... write your Connect Software to MAKE UP for the missing features/possibilities in the instrument
/rant over
Offline serggio
  • Country: ru
Re: Fluke 279 FC
« Reply #11 on: April 29, 2016, 08:39:44 pm »
I agree with you. They need add some possibilities for logging in Fluke Connect. For now this like meter option in Fluke View Form. But if you need wireless freedom for logging it simple to do with Bluetooth to COM emulation for connect your DMM or other equipment to FLVF. I do not see any practical reason to have logging option in mobile application for long term logging. You need to have your mobile device continuously connected with meter for that and problem of power will be not only for meter.
As for access to stored data while logging process (realtime graph with rewind), that cannot doing 287/289 DMM, I think that this is microprocessor HW limitation that used in this DMMs. DMMs performing very fast measuring for fast changing signals (that can be considered as events) and this measuring need to be stored in memory. If you want to have simultaneously access to memory for read and write you need to have big fast RAM buffer inside microprocessor and high frequency. This will be far away from 20-30 mA consumption during logging. I don't know about  287/289 series, but 189 have buffer for 10 last records that can be FLVF can access during measuring.
Offline BMack
Re: Fluke 279 FC
« Reply #12 on: April 30, 2016, 05:44:08 am »
FLIR (not shockingly) was first to market with a clamp meter with thermal imaging, the CM174...I believe I saw that they had or will have a multimeter with thermal as well.
Offline retiredcaps
Re: Fluke 279 FC
« Reply #13 on: May 29, 2016, 10:08:53 pm »
Martin's video.
Offline Per Hansson
Re: Fluke 279 FC
« Reply #14 on: July 03, 2016, 03:20:58 pm »
Does anybody know if the sensor used in this is the same as in the CAT S60 smartphone which uses a FLIR Lepton sensor with 80×60 active pixels?
