Author Topic: 53132A bad display  (Read 8063 times)
Offline uncle_bob
Re: 53132A bad display
« Reply #25 on: May 22, 2016, 12:45:25 pm »
There has to be a reason. When I pull mine apart to change the display board I'll check the temps on the SMPS. If the fan is indeed cooling off the supply I should  be able to see it.
Could it be that your supplies are going for another reason, are you sure it is the fan being off? I've been monitoring the fan all night with the instrument on and then off. I'm just not seeing any great variation in the temp, maybe a degree or two but several variables could be causing it.
I think Gerry's been running for awhile with his mod.
Rob
Hi
Once we started replacing fans, the supplies stopped dying.....
Bob
Offline Robaroni
  • Retired EE
    • Design Specialties
« Reply #26 on: May 22, 2016, 01:23:39 pm »
Replacing fans? Are you saying the fans went bad?
R
Offline uncle_bob
« Reply #27 on: May 22, 2016, 01:35:35 pm »
R
Hi
Nope, the dirt and the like got them really noisy. I suspect they were not moving as much air as they should have. We started pulling them wholesale and that did the trick.
Bob
Offline Robaroni
  • Retired EE
« Reply #28 on: May 22, 2016, 01:46:26 pm »
Uncle Bob,
Did these counters have any of the oven options?
Rob
Offline uncle_bob
« Reply #29 on: May 22, 2016, 01:53:48 pm »
Uncle Bob,
Rob
Hi
Nope, we run them all of of external standards in multiple plants. They were purchased over at least a 10 year span, so no, we didn't get a uniquely bad batch. It took us a while to figure things out. A lot of 53181's bit the dust "donating" their power supply to the 131's and 132's. Yes, hanging on to the rest of the chassis (for the DISPLAY) would have been a really good idea.
Bob
Offline Robaroni
  • Retired EE
« Reply #30 on: May 22, 2016, 02:03:38 pm »
Good to know, I'll make sure to check temps on the SMPS when I pull it apart to change the display.
You should have kept the displays!
We never throw anything out.... Sometimes this can work to our disadvantage! ;D
Rob
Offline uncle_bob
« Reply #31 on: May 22, 2016, 03:39:36 pm »
Rob
Hi
We tend to do the same thing. When it gets to the point that you are renting space in multiple locations to keep "stuff" the finance boys start to get into the act. Eventually an edict comes down. Unfortunately I do the same thing here at home. The space runs $550 a month. That's about $100,000 over the last 15 years or so. Want to bet I could buy a lot brand new gear for $100K? Same logic applies at work except their rent was running about 10X mine.
Bob
Offline Robaroni
  • Retired EE
« Reply #32 on: May 22, 2016, 10:40:06 pm »
Uncle Bob,
Let me put this into perspective, my wife Nancy calls it the Robsonian!
Rob
Offline uncle_bob
« Reply #33 on: May 23, 2016, 12:03:01 am »
Uncle Bob,
Rob
Hi
My wife is far less kind when referring to my collection of "fine stuff" ....
Bob
Offline bitseeker
« Reply #34 on: May 23, 2016, 01:45:54 am »
I think if my stuff got a name it'd become part of the family. So, no naming here. However, the Robsonian sounds like a nice place to visit.
I TEA.
