Author Topic: Agilent 600MHz 54831B hack for 1GHz 54832B possible? YES!  (Read 17081 times)
Offline sergej
  • Country: sk
Re: Agilent 600MHz 54831B hack for 1GHz 54832B possible? YES!
« Reply #25 on: August 15, 2024, 07:43:15 am »
Did anybody figure how to enable higher memory options?
Low serial numbers (like mine) do have up to 16Mpts already on board but mine does not have any memory option and only has 4Mpts enabled.
A software key enables 04 and 08 memory options which I really need . Has anybody figured how to do that?
higher serial numbers have the highest memory already installed and need software key to enable them
Any new information about this ?
I have 54831M with only 2Mpts memory :-(
Offline ua4yhz
« Reply #26 on: October 08, 2024, 11:27:06 am »
The option is enabled with a license key. The maximum I could enable was 64 MPts on 54833A.
« Last Edit: April 08, 2025, 01:36:17 pm by ua4yhz »
Offline sergej
  • Country: sk
« Reply #27 on: November 21, 2024, 06:54:21 pm »
Yes, I know it. But how I obtain the license code :-)
Offline sergej
  • Country: sk
« Reply #28 on: February 08, 2025, 03:36:28 pm »
Confirmed. My 54831B (M) is now 54832B (M). But must be recalibrated, in my case.
Offline Karnathe
  • Country: zw
« Reply #29 on: April 08, 2025, 02:51:43 am »
Just did this incredibly difficult mod to my 54830B, can confirm it now thinks its a 1ghz model! Running self test currently, thank you so much for publishing this!! Now I just have to figure out how to get more licenses for it, does anyone here have any experience on that? I can start a new thread if needed, not sure how that should be done.
Offline bostonman
« Reply #30 on: April 10, 2025, 02:25:14 am »
I'm slightly confused about the this thread. Is the modification for increasing BW to 1GHz (i.e. removing the resistor - which I've already done) or increasing memory?
If it's increasing memory, which steps are needed? I'm always interested in improving my scope.
Offline ua4yhz
« Reply #31 on: April 22, 2025, 09:44:39 am »
The memory on this oscilloscope can be expanded with a license key.
The license key is generated according to the oscilloscope's option ID.
Circled in blue.
« Last Edit: April 22, 2025, 09:52:34 am by ua4yhz »
Offline bostonman
« Reply #32 on: April 22, 2025, 12:46:14 pm »
How is the key generated? Not sure I have a "license key generator". The OS on my scope was an image someone on here provided which already had several options enabled.
Offline bostonman
« Reply #33 on: April 25, 2025, 12:12:11 pm »
I got your PM but it won’t allow me to attach photos in a PM.
For some reason one of my two scopes has garbled characters.
Offline bostonman
« Reply #34 on: April 26, 2025, 04:28:42 pm »
What is the voice option?
I don’t know why the numbers are garbled. They were fine before when I installed the image; and I used the same image on bitg scopes.
Maybe I’ll have to reinstalled the whole image again when I won’t look forward to.
Offline bostonman
« Reply #35 on: April 28, 2025, 09:42:27 pm »
Unfortunately the keys didn't work on either scope.
The message was: License installation failed. The license is not compatible with this product. Please contact Agilent technical support.
Offline ua4yhz
« Reply #36 on: April 29, 2025, 05:43:51 am »
Can you send me a file from your oscilloscope license.dat for study?
Offline bostonman
« Reply #37 on: April 30, 2025, 02:35:49 am »
Attached are the license files I found. They look very plain, so not sure what you'll see in them.
I made two directories. One is named 'Corrupt Number' and that's the scope with the garbled characters and the other 'Good Number' is the scope with the good characters.
Offline ua4yhz
« Reply #38 on: April 30, 2025, 06:35:34 am »
My key generator doesn't work for "B" model oscilloscope, it works only for model "A".
Apparently model "B" is newer and uses a different algorithm.
Offline bostonman
« Reply #39 on: April 30, 2025, 01:15:10 pm »
Ah okay.
It was an 'M' version before I removed the resistor to increase the BW.
Also, I noticed the option ID number was garbled before too (I had taken a picture of the screen and saved it). The image used was the same for both oscilloscopes, and both got the resistor removed, however, one has garbled numbers and the other doesn't.
How do I know what rate my scope is viewing at (32MPts or 64MPts)?
Offline ua4yhz
« Reply #40 on: April 30, 2025, 02:46:09 pm »
You have the 8 MPts option installed.
Offline bostonman
« Reply #41 on: May 01, 2025, 01:03:37 am »
Looking through my notes and files, it looks like I can edit the license file to add the 64MPts.
What is the advantage/disadvantage of increase it?
I'm afraid that the scope will run slower due to its limited RAM. This is why I didn't install additional options; and resulted in forgetting I had notes on it. Will one disadvantage be a slower scope and may mess up measurements?
Offline ua4yhz
« Reply #42 on: May 05, 2025, 05:41:07 am »
The oscilloscope will not work slower, don't worry. How and what do you want to change?
Offline bostonman
« Reply #43 on: May 05, 2025, 12:45:06 pm »
Going through my notes, I have a text document with numerous options. If I remember correctly, it was a dump from a ROM or whatever and the names aren't obvious as to what the option does.
Since we are on the topic of MPts (I assume mega points), and mine is only at 8MPts, I'm guessing increasing this will provide better resolution.
To answer your question, I guess this would be on option to change, but not sure what advantages it has.
From reading, someone added every option and it caused slow boot time for the scope. If every option is added, or many options added, how does this not slow down the scope?
I'd assume it uses RAM to have the options enabled.
Offline baldengineer
  • James
    • Personal Blog
« Reply #44 on: May 05, 2025, 01:55:31 pm »
It depends on what you mean by "resolution."
The acquisition memory depth for storing samples. Sometimes called the acquisition buffer. It enables the sample rate to stay higher at longer time bases. Or to capture longer time bases with lower sample rate.
At the time when this class of Infiniium was launched, it had the "MegaZoom ASIC." It is a memory controller that helps manage deep acquisition memory. Its primary feature was that the screen stayed responsive and the update rate stayed fast when capturing longer buffer lengths. Other oscilloscopes at the time would always transfer the entire acquisition buffer to the CPU which took a long time. If no measurements are turned on, MegaZoom only transfers enough data for a reasonable display. Essentially, it was a very intelligent decimator.
Fan of making things beep, blink, and fly.  AddOhms video creator, KN6FGY. Oh, and Bald.
Offline bostonman
« Reply #45 on: May 06, 2025, 03:03:35 am »
Makes a bit more sense. I was thinking it was "resolution" in the sense of samples it collects.
Attached is the list of "upgrades" that can possibly be added; I mentioned this file a message or two ago.
They are not defined, so I'm uncertain about the function of each one. At the end is something called '64MPts' which I assume is the upgrade in discussion now.
I'm really not in need of making my scopes have more bells and whistles, but any performance upgrades/enhancements would be nice.
Why is it that enabling features will not slow the scope? Believe I asked this in either this thread or another, but not sure I understood the answer. Seems to me the more features enabled results in eating more RAM.
Offline ua4yhz
« Reply #46 on: May 07, 2025, 05:31:21 pm »
This is a list of all the options that can be installed on your oscilloscope.
Offline bostonman
« Reply #47 on: May 07, 2025, 09:47:56 pm »
Yes, I assumed, however, nothing defines what they mean.
Also, why would the scope not run slower with additional options?
