Author Topic: 5uH LISN schematic varies?  (Read 405 times)
Offline FaringdonTopic starter
« on: May 19, 2024, 08:12:30 pm »
Page 2 of this...
https://www.tekbox.com/product/TBL0550-1_Manual.pdf
..shows a 5uH LISN with a 5uH inductance.
But 07:25 of this video, shows the 5uH  LISN schematic with some 470R resistors connected across the inductance..
Do you know which one is used by the  standards bodys?
Also, what is the output filter of the power supply used at the EMC labs, upstream of the LISN? (pse see attached).....its output CLC filter affects the peak of the ring-up voltage when the DUT is suddenly switched ON....there is a danger of overvoltaging something at the DUT.
« Last Edit: May 19, 2024, 08:32:06 pm by Faringdon »
'Perfection' is the enemy of 'perfectly satisfactory'
