All my RF probes here are either homemade or salvaged from a skip and repaired.
For a bit of fun I had a go at making and testing a very crude pad to match 75R to 50R using cheapo SMD resistors.
I know how my SMD resistors here behave up at several GHz so I knew this pad would not be that great. If I had access to more choice in terms of SMD resistor package (like I have at work) I could do much better.
But see below for a plot of the response of a pad that cost about a penny in parts. OK, it's on a low loss test fixture made with a decent PCB but I have de embedded the result to just show the response of the resistor section. This is a real pad measured on a VNA calibrated with an Ecal module.
You can see that the RF performance is a bit better behaved. I'd probably embed 75R semi rigid into a real design and use a decent 75R N connector at the input and then use a decent 50R connector at the output. With better SMD resistors and some fiddling I think I could get the VSWR at 6GHz much better than this
The performance begins to unravel just above 5GHz in the plots below but it manages to keep the VSWR below 1.4:1 even with this early/crude attempt.
