Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
8340B or modified 8341B?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 8340B or modified 8341B? (Read 1144 times)
pe2ben
Contributor
Country:
on:
August 02, 2023, 10:07:52 am »
Hello,
I have a 8340B with a N RF output connector.
On other 8340B pictures i only see SMA RF output connectors.
Could it be that i have a modified 8341B or are some 8340B's are delivered with N RF connector?
Thanks, Ben
Logged
Tony_G
Frequent Contributor
Country:
Checkout my old test gear channel (link in sig)
Re: 8340B or modified 8341B?
Reply #1 on:
August 02, 2023, 07:02:32 pm »
Interesting - I'm only ever seen the 8340B's with an APC 3.5mm connector on them (not an SMA) but I think that HP did do a specific version of the N-Type connector that they specified up to 26.5GHz (or maybe it was 20GHz, can't remember I looked it up quite some time ago) so there might have been an option to get the 8340B with that as the RF connector.
That said, I looked for a HP catalog that mentioned the units and saw this:
So maybe what you have is a frankenunit...
TonyG
Logged
TGSoapbox - Test Gear Playlist
pe2ben
Contributor
Country:
Reply #2 on:
August 04, 2023, 12:16:54 am »
Hi Tony,
I read that also.
I hoped that maybe an older version had the N connector because the calibration sheet inside with the correct s/n# show me calibration data range is including 26.5 GHz. Strange...
Regards Ben
Logged
dxl
Regular Contributor
Country:
Reply #3 on:
August 23, 2023, 07:33:10 pm »
My 8340A had an a APC-3.5mm connector initially - but it was broken, so i replaced it with an N connector from other HP gear that was specified up to 26.5GHz. At least for the 8563E spectrum analyzer they had to made a 'high-frequency' N connector i guess...
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
