PEM make nice rogowski coils. For voltage sensing, I would recommend an isolated or differential high voltage probe since the short circuit event can cause jumps in the ground potential, something like a tektronix THDP0100. I've had good results on double pulse tests running at similar voltages and currents as those you mentioned, just neither are exactly a cheap option.
