Author Topic: ATTEN ADS1102CAL "FPGA not loaded"  (Read 2327 times)
Offline ds18s20Topic starter
« on: March 26, 2015, 05:18:33 am »
Hello. I need help. My oscilloscope ATTEN ADS1102CAL was died some time ago. When I turn the power  I see the message "FPGA NOT LOADED" on screen. What can I do with this?
Offline pickle9000
Re: ATTEN ADS1102CAL "FPGA not loaded"
« Reply #1 on: March 26, 2015, 05:29:33 am »
That's a Siglent SDS1102CNL. You can try installing the Siglent firmware it will change your splash screen but otherwise the same.
Of course if you have Atten firmware use that instead.
