Author Topic: "nktech nk-51h" - proper way of installing battery/fast look inside  (Read 458 times)
Offline IAmBack
Hi.
I've purchased this meter on ebay for... $1. And it just arrived! Unbelievable (no matter how cr***y this toy will happen to be). But I have one problem: what is the proper way of installing battery? Meter has two contacts (like for AA/AAA batteries, but 9V battery has to be installed) and no single mark of polarity...
Anyone has experiences with this unit?
« Last Edit: January 04, 2018, 09:36:40 pm by IAmBack »
Offline casinada
Re: "nktech nk-51h" - proper way of installing battery
« Reply #1 on: January 04, 2018, 03:55:31 pm »
There is an opening that shows the pcb and there is a "-" sign in the solder mask that is the negative side.  :-//
Offline IAmBack
Re: "nktech nk-51h" - proper way of installing battery/fast look inside
« Reply #2 on: January 04, 2018, 09:53:51 pm »
Thank You for help.
I've opened this meter and made several photos.
The "-" sign on PCB is not the marking for negative terminal, but anyway - it works.
Big fuses I see :)
