My personal issues...
- I often forget to power of the devices, so I accidentally use the DMM in resistance mode when the circuit is powered on. This means most DMMs end broken or need constant fuse replacement, very often both things happens.
- I need autorange, because ranging drives me insane most of the time.
I tried to change my bad habits, but it's a PITA to change them. I'm very absent minded...
Would I need a good DMM + Transistor Tester project be a good combination for me? I can learn whatever is needed, but I need inattentive-proof equipment
Kind regards.
