Products => Test Equipment => Topic started by: TomerP on August 19, 2017, 04:33:03 pm
Hi, is there a DMM with a PC connection for logging (either USB/COM) that also costs less than 20$?
It would probably need to be second hand if there was one.
If accuracy is not that important then alternatives such as the analogue inputs on a rasberry pi might be an option.
The least expensive data logging meter that I know of is the Digitek DT-4000ZC, also known as TekPower TP4000ZC. They sell for around $40.
It first sold for around $29 USD when I brought it to Martin's attention 5+ years ago. Then it got popular and sellers raised prices.
http://www.mjlorton.com/forum/index.php?topic=81.0 (http://www.mjlorton.com/forum/index.php?topic=81.0)
https://www.youtube.com/watch?v=kXzAD74C5As (https://www.youtube.com/watch?v=kXzAD74C5As)
https://www.youtube.com/watch?v=7pbRLom7bNc (https://www.youtube.com/watch?v=7pbRLom7bNc)
What do you need to measure? How accurate?
Vdc and Current, as accurate as 1% I guess.
How many volts? How many amps? Will you need to switch voltage ranges or is it fixed?
220v ac, much less dc, up to 30 amper (I don't know if its a reasonable requirement for that price range)
a) You don't really need to measure 220V AC, it hardly ever gives a wrong value (not unless you're using a generator or something).
b) Look into current clamps for Arduino.
https://encrypted.google.com/search?q=arduino+current+clamp
true, but measuring dc voltage of up to lets say 50v is something I'd like to be able to do with it
Make a 10:1 resistor divider, connect it to the Arduino.
