What I'd love to see is this kind of talent go into a really top notch open source firmware for one of the existing inexpensive scopes. The firmware is usually where most of the flaws are in these things, of course the problem is the difficulty of reverse engineering someone else's hardware which invariably has no documentation whatsoever these days. When aftermarket firmwares came out for consumer internet routers it was a game changer and I'm betting the same thing could be done with a scope.
This has been discussed to death. It cannot be done in a time frame needed. Reverse engineering existing scope to the point that you understand everything about it's architecture is much harder than simply designing one from the scratch. There were dozens of attempts, that ended up with loading custom linux on scopes, and no way to talk to acquisition engine. Mainly running Doom on scope.
Scope architecture is interleaved design, hardware acquisition, hardware acceleration, system software, scope software and app side acceleration (gpu etc..)
Design decision have been made by manufacturers how to implement it. You end up with something that, in the end, won't have much more capabilities that what it had in the start. You just spent 20 engineer years to have same capabilities and different fonts...
Only way that maybe would make sense to try would be if existing manufacturer would open their design (publish all internal details) as a starting point. Which will happen, well, never.
FOSS scope for the sake of FOSS is a waste of time. GOOD FOSS scope is not... If good FOSS scope existed, it would start to spread through academia, hobby, industry and if really used, that would fuel it's progress. Remember Linux and Kicad... When did they take off? When they became useful and people started using them, not when they became free. They existed and were free for many years and happily ignored by most.
And then you would have many manufacturers that would make them for nominal price. It would be easy for them. like Arduino and clones. Someone did the hard work of hardware design. And someone else will take care of software... That is a dream for manufacturing.. Very low cost... I bet you that what we estimate now to be 600 USD could be had for 300 USD (or less) if mass manufacturing happens...
