I took a quick look, there are less expensive alternatives. The question is what does it use for a detector? ADC resolution? How about the master oscillator phase noise? The dynamic range isn't all that great at 100db but would be about 20db over the $350-$600 range which come in at 80db. Depends on your needs I guess. These things are coming down in price but many use AD phase detectors and log amps that have limited dynamic range, cheap oscillators, 16bit ADC, etc. a good, low phase nois, low jitter, master oscillator could cost you $120 by itself, for instance. See if you can find the schematic.
