Author Topic: A possibly dumb Q on digital oscilloscopes  (Read 38321 times)
Online nctnico
Re: A possibly dumb Q on digital oscilloscopes
« Reply #175 on: October 02, 2017, 08:06:01 pm »
Technically: RS485 is (like RS232, RS422, etc, etc) only an electrical interface specification so you can run any kind of bit pattern over it which forms a communication layer.
However, if there is a UART signal over any of these kind of links you should be able to decode it using the UART decoder. It is a matter of setting the right threshold and polarity (and the regular UART parameters ofcourse).
Offline peter-hTopic starter
« Reply #176 on: October 02, 2017, 09:16:36 pm »
What is the difference between UART and RS232? You can set a threshold for either mode.
I know what you mean about interface versus protocol etc and I have run e.g. Manchester using RS485 chips, but normally RS422/485 is just a differential version of RS232. The data encoding is the same i.e. NRZ, with a start bit, x data bits, 1 stop bit... To decode this in the correct differential way the scope would need a facility for subtracting two channels, otherwise the decoding is just like RS232.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #177 on: October 03, 2017, 06:49:19 pm »
One thing we could not find today was decoding data on RS422/485 i.e. the difference between two signals. There is one option called RS232, and one called UART which I assume is the TTL level at a microcontroller i.e. inverted version of RS232.
According to this datasheet, the UART is a bit more configurable.
Online tggzzz
« Reply #178 on: October 03, 2017, 07:49:38 pm »
... and to grok what isn't being said and what isn't being specified.
The following users thanked this post: rsjsouza
Offline rsjsouza
  • Eternally curious
« Reply #179 on: October 03, 2017, 09:35:11 pm »
Good one!
« Reply #180 on: October 11, 2017, 06:20:25 pm »
Many thanks, rsjsouza. There is way more functionality in this than I had realised, or saw in the config pages.
« Reply #181 on: October 24, 2017, 07:20:12 am »
Does the WS3034 have the capability to look at e.g. RS422 the correct way i.e. decode the two signals differentially?
Offline Hydron
« Reply #182 on: October 24, 2017, 07:38:08 am »
Can you use a maths function to find the difference between the two signals, then run the decode on that result?
Offline borjam
  • EA2EKH
« Reply #183 on: October 24, 2017, 07:51:27 am »
I would guess it's possible to use "MATH" as a source on a LeCroy. I was surprised by the ancient 9400 and how it allows you to stack operations using "MATH" as a source.
That said, in order to debug RS422/RS485 I think that a differential probe is almost mandatory. Especially with long cable runs. Common mode voltages can be a problem otherwise.
I use a Hameg HZ109 myself. You don't need a lot of bandwitdh.
