Author Topic: A quick teardown of Capasitor Wizard ESR Meter, a few pictures.  (Read 29893 times)
Offline ErikTheNorwegianTopic starter
  • Country: no
  • Asberger, aspi, HIGH function, nerd...
Re: A quick teardown of Capasitor Wizard ESR Meter, a few pictures.
« Reply #25 on: March 14, 2014, 03:51:22 pm »
The curves 47mF 10volts capasitor.
CAP-1B
 EDS-88A
Both tips, the CAP-1B has Fluke gator attached.
DST-88A custom made tip
« Last Edit: March 14, 2014, 04:02:21 pm by ErikTheNorwegian »
/Erik
Goooood karma is flowing..
Offline P90
« Reply #26 on: October 06, 2016, 02:07:19 am »
I know this is an old post, but I have to say,  that has to be the most horrendous and despicable soldering and overall pisspoor construction I have ever seen. It's a total hack job. Who builds these things, Ray Charles? They brag about made in USA, yet I have not seen a single Chinese electronics made this poorly. What a disgrace...
Offline Hydrawerk
« Reply #27 on: October 06, 2016, 10:54:16 am »
Well, Capacitor Wizard is probably a 100% design from 1995. Nowadays you can buy or build an AVR component tester
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/
http://www.mikrocontroller.net/svnbrowser/transistortester/
or buy a Cyrustek chipset based LCR 100kHz meter like CEM DT-9935 or many others.
I think that most people know well about this.
Offline P90
« Reply #28 on: October 29, 2016, 10:28:47 am »
Who in his right mind would buy that garbage Capacitor Wizard?
Offline Gyro
« Reply #29 on: October 29, 2016, 08:03:56 pm »
Anything of value in your post?  :-//
Best Regards, Chris
Offline Bud
« Reply #30 on: October 29, 2016, 09:01:47 pm »
Then you have not seen much. Watch EEVBlog #822.
« Last Edit: October 29, 2016, 09:06:49 pm by Bud »
  • Country: no
« Reply #31 on: December 03, 2023, 12:24:22 pm »
Component side.
/Erik
The following users thanked this post: kripton2035, BILLPOD
Offline kripton2035
« Reply #32 on: December 03, 2023, 02:26:26 pm »
subscribed...
Offline Hydrawerk
« Reply #33 on: December 31, 2023, 09:35:36 pm »
Well, this capacitor wizard was good back in 1995. https://www.midwestdevices.com/index.php
It might do the job. $239.95 USD is too much. You can buy a handheld LCR meter for that. I just randomly found this... https://eleshop.eu/de-ree-de-5000-lcr-meter.html
I have my CEM DT-9935 lcr meter since 2012...
https://www.eevblog.com/forum/testgear/cheap-lcr-meter-cem-dt-9935/
Offline Hydrawerk
« Reply #34 on: December 31, 2023, 09:44:21 pm »
Component side.
It looks ugly, but it might work just OK.
There are some asian made LCR meters in a similar price range as the capacitor wizard.
https://www.tequipment.net/ExtechLCR200.asp
https://www.electron.com/digital-multimeter-rlc-uni-t-ut612-p54037/
OK, straight away, I can tell from the first photograph that what you have there will be based on the same chipset as a large number of other mid-range LCR meters that use the same cyrustek ES51990 chipset, also found in Mastech Ms5308 (which I have), GenRad/IET DE5000, to name but two of many.
Offline Hydrawerk
