Author Topic: A quick teardown of Capasitor Wizard ESR Meter, a few pictures.  (Read 28234 times)
Offline ErikTheNorwegianTopic starter
  • Country: no
  • Asberger, aspi, HIGH function, nerd...
http://midwestdevices.com/
Capacitor Wizard® Operating Manual
http://midwestdevices.com/_pdfs/Capmanual9.pdf
ESR: Methods of Measurement
http://midwestdevices.com/_pdfs/Tnote3.pdf
Missing som strain relef here?
After some testing of capacitor tester with the tester i will come back with a test report..
« Last Edit: March 11, 2014, 09:30:26 pm by ErikTheNorwegian »
/Erik
Goooood karma is flowing..
Offline JoeO
  • I admit to being deplorable
Re: A quick teardown of Capasitor Wizard ESR Meter, a few pictures.
« Reply #1 on: March 11, 2014, 09:27:39 pm »
A black and a red wire both going to the same place on the meter?
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
Offline edpalmer42
« Reply #2 on: March 11, 2014, 09:39:38 pm »
Note that there's a second yellow sticker with no wire.  Looks like the original meter's studs poked through where the yellow stickers are and the current meter has a smaller movement.
Ed
Offline Shock
« Reply #3 on: March 12, 2014, 04:20:37 pm »
Pretty horrible soldering job.
Online BravoV
  • +++ ATH1
« Reply #4 on: March 12, 2014, 04:26:06 pm »
Don't mean to rain your parade, but at $230 a pop its just way too much imho.  :palm:
Offline zaoka
« Reply #5 on: March 12, 2014, 05:08:19 pm »
This meter had advantage that goes up to 50ohm and scale between 0-1 is almost 25% of the scale.
Its way expensive...
Offline mos6502
  • Country: aq
« Reply #6 on: March 12, 2014, 05:20:15 pm »
Yeah, you can get a real LCR meter that will actually measure ESR accurately with milliohm accuracy for half the price.
Not to mention L and C  :)
for(;;);
Offline free_electron
    • SiliconValleyGarage
« Reply #7 on: March 12, 2014, 06:22:35 pm »
that is not soldered. it looks more like someone had a big ball of liquid solder , farted over it and the spray landed on the board ...
Offline tom66
« Reply #8 on: March 12, 2014, 06:54:51 pm »
An ATLAS PEAK ESR meter with a digital readout costs £70, are they having a laugh with $230??
Offline Hydrawerk
« Reply #9 on: March 12, 2014, 07:08:50 pm »
This capacitor wizard is IMHO obsolete and overpriced. Moreover it is a 1995's technology.
Offline Axtman
« Reply #10 on: March 12, 2014, 07:25:49 pm »
What do you guys think of the CapAnalyzer 88A Series II?
http://www.eds-inc.com/cap.html
  • Country: no
« Reply #11 on: March 12, 2014, 07:34:01 pm »
I actually have one of those to... so i will make a comparison of them.  :)
« Last Edit: March 12, 2014, 07:39:20 pm by ErikTheNorwegian »
/Erik
Offline mos6502
  • Country: aq
« Reply #12 on: March 12, 2014, 07:37:07 pm »
For $50? Worth considering if you're doing a lot of repairs.
For $229 (which is what they're asking for)? YGTBSM.
for(;;);
Offline PA0PBZ
« Reply #13 on: March 12, 2014, 07:42:23 pm »
Nice, but... what's on the component side of the pcb?
  • Country: no
« Reply #14 on: March 12, 2014, 07:44:00 pm »
You dont use speakers then, they are som 1920`s technology, and has not developed much from the original concept.  :P
/Erik
Offline Hydrawerk
« Reply #15 on: March 12, 2014, 08:40:20 pm »
Is this Capacitor wizard someway different from these well-known schematics of ESR meters?
https://www.eevblog.com/forum/projects/5-transistor-esr-meter-design/
Offline tom66
« Reply #16 on: March 12, 2014, 08:59:29 pm »
Ah, but this one has a low battery detect.  ;D
Offline kc9qvl
« Reply #17 on: March 12, 2014, 10:00:31 pm »
How about a look at the component side.  :)
Offline The Electrician
« Reply #18 on: March 12, 2014, 11:18:52 pm »
It is claimed that the Capacitor Wizard applies a sine wave to the DUT:
Erik, would you connect a capacitor that's not too big, say a 10 uF electrolytic, to the capacitor wizard and look at the waveform across the cap with a scope to verify if it's really a sine wave?
  • Country: no
« Reply #19 on: March 13, 2014, 12:21:35 am »
Will try that tommorow if i get outa bed.  ;)
 (Have no helpers tommorow, so may stay i bed all day if i dont get out mysellf. )
/Erik
Offline Jay_Diddy_B
« Reply #20 on: March 13, 2014, 09:21:02 am »
This is interesting reading.
It tells you how to repair the Capacitor Wizard:
http://www.midwestdevices.com/_pdfs/Sbullit8.pdf
Here is a picture showing part of the board, component side:
http://howardelectronics.com/ieinc/images/Capwizsavr%201.jpg
There is another picture here:
https://www.howardelectronics.com/ieinc/CapSVR%20Install%20Instructions.pdf
This patent describes the protection circuit:
http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&p=1&u=%2Fnetahtml%2FPTO%2Fsearch-bool.html&r=1&f=G&l=50&co1=AND&d=PTXT&s1=%22Capacitor+Wizard%22&OS="Capacitor+Wizard"&RS="Capacitor+Wizard"
If you want an ESR meter with really good protection, build the ESR meter adapter described in this thread:
https://www.eevblog.com/forum/projects/esr-meter-adapter-design-and-construction/msg341177/#msg341177
Regards,
Jay_Diddy_B
« Last Edit: March 13, 2014, 09:33:13 am by Jay_Diddy_B »
« Reply #21 on: March 13, 2014, 04:15:17 pm »
I wonder if the "CapSVR" add-on kit is just the transformer/diode arrangement described in the patent.
  • Country: no
« Reply #22 on: March 13, 2014, 08:27:32 pm »
The Capacitor Wizard model CAP-1B had a rather "bursty" sinus 102,8 KHz. 3,2 mV
and the Electronic Design Specialist  EDS-88A CapAnalyzer II had the same "noisy" more triangle than sinus 124KHz  ant 3 mV.
Se if i can get some pictures taken if its of interest, but really nothing to see.
The reason i bought the CAP-1B from Capacitor wizard, is that the "wand" (Probes are way better to use on some cards than the tweeter with thin copper contacts) on the EDS-88A is way better. Lock at the pictures. The tweezers is ok on small boards where you have to/can use it with one hand. But if there is a lot of corrosion, lacquer etc. on the board, the sharp probes of the CAP-1B is the best, but i have to use both hands.  Fluke AC72 Alligator Clip Set fits right on, and makes it easy to connect onto a capacitor if necessary. I must say that both testers do what they claim, easy and very quick. I enjoy the different beeps of the EDS-88A when fast going over a ex mainboard on a computer, don’t need to look at the meter, if good or bad. But if in doubt, the table has to be searched and you have to read the table for info. That takes time. And the automatic discharging that the CAP-1B don’t have is a big plus on some jobs.  The CAP-1B, has a meter that is clearly marked BAD - COMPAERE - GOOD and is quicker to read. So i guess, both meters has its + and -. Some like the mother, some the daughter and nerds are hands on, as we say here in Norway!
There is a place for both on my bench. (Instruments that is!)
« Last Edit: March 13, 2014, 09:23:45 pm by ErikTheNorwegian »
/Erik
Offline Jay_Diddy_B
« Reply #23 on: March 13, 2014, 11:17:54 pm »
From the photographs I believe that it does. It is the circuit from the patent plus a coupling capacitor in series with the transformer primary. The idea is for large voltage the diodes conduct and the current in the two windings cancel. For small signals the diodes do not conduct and it behaves like a transformer.
I am not sure how well it works.
Jay_Diddy_B
« Reply #24 on: March 14, 2014, 12:58:46 am »
Jay_Diddy_B
The patent says the transformer has to resonate at the frequency which is applied to the DUT, and then it works well.
  • Country: no
« Reply #25 on: March 14, 2014, 03:51:22 pm »
The curves 47mF 10volts capasitor.
CAP-1B
 EDS-88A
Both tips, the CAP-1B has Fluke gator attached.
DST-88A custom made tip
« Last Edit: March 14, 2014, 04:02:21 pm by ErikTheNorwegian »
/Erik
Offline P90
« Reply #26 on: October 06, 2016, 02:07:19 am »
I know this is an old post, but I have to say,  that has to be the most horrendous and despicable soldering and overall pisspoor construction I have ever seen. It's a total hack job. Who builds these things, Ray Charles? They brag about made in USA, yet I have not seen a single Chinese electronics made this poorly. What a disgrace...
Offline Hydrawerk
« Reply #27 on: October 06, 2016, 10:54:16 am »
Well, Capacitor Wizard is probably a 100% design from 1995. Nowadays you can buy or build an AVR component tester
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/
http://www.mikrocontroller.net/svnbrowser/transistortester/
or buy a Cyrustek chipset based LCR 100kHz meter like CEM DT-9935 or many others.
I think that most people know well about this.
Offline P90
« Reply #28 on: October 29, 2016, 10:28:47 am »
Who in his right mind would buy that garbage Capacitor Wizard?
Offline Gyro
« Reply #29 on: October 29, 2016, 08:03:56 pm »
Anything of value in your post?  :-//
Best Regards, Chris
Offline Bud
« Reply #30 on: October 29, 2016, 09:01:47 pm »
Then you have not seen much. Watch EEVBlog #822.
« Last Edit: October 29, 2016, 09:06:49 pm by Bud »
  • Country: no
« Reply #31 on: December 03, 2023, 12:24:22 pm »
Component side.
/Erik
The following users thanked this post: kripton2035, BILLPOD
Offline kripton2035
« Reply #32 on: December 03, 2023, 02:26:26 pm »
subscribed...
Offline Hydrawerk
« Reply #33 on: December 31, 2023, 09:35:36 pm »
Well, this capacitor wizard was good back in 1995. https://www.midwestdevices.com/index.php
It might do the job. $239.95 USD is too much. You can buy a handheld LCR meter for that. I just randomly found this... https://eleshop.eu/de-ree-de-5000-lcr-meter.html
I have my CEM DT-9935 lcr meter since 2012...
https://www.eevblog.com/forum/testgear/cheap-lcr-meter-cem-dt-9935/
Offline Hydrawerk
« Reply #34 on: December 31, 2023, 09:44:21 pm »
Component side.
It looks ugly, but it might work just OK.
There are some asian made LCR meters in a similar price range as the capacitor wizard.
https://www.tequipment.net/ExtechLCR200.asp
https://www.electron.com/digital-multimeter-rlc-uni-t-ut612-p54037/
OK, straight away, I can tell from the first photograph that what you have there will be based on the same chipset as a large number of other mid-range LCR meters that use the same cyrustek ES51990 chipset, also found in Mastech Ms5308 (which I have), GenRad/IET DE5000, to name but two of many.
Offline Hydrawerk
