Well, if they're going to put two meters in the same case, then you might as well buy two meters and skip paying the novelty price.
FWIW, even my Fluke bench meter (Fluke 45) has a dual display mode, and it's even more limited because not only do the two channels share ground, there is still only one V input. You can display V/mA, VAC/Hz, VDC/VAC, and a few other combinations. Still, I've found it useful.
