Author Topic: AC Power meter  (Read 2553 times)
Offline eetechTomTopic starter
AC Power meter
« on: July 29, 2014, 05:34:53 pm »
Greetings! Time to start my first topic on this forum.
I am looking to purchase 4 or 5 AC Power meters for an undergrad machines lab. The minimum requirements are 220v single phase, 20A maximum. A scale/display for voltage and watts are also minimum requirements. The existing experiment these are used in connects to a 5A CT. We only require single phase measurements currently but am thinking of ordering something with 3 phase capability in case it is needed in the future. I am hoping to stay under $500 each, and can add I/O connectors and enclosure myself if necessary. The instrument itself will be powered by 120 vac ideally.
P.S. Need to order from a US distributor.
I'm hoping to avoid solitcing quotes on instruments that are above budget so any general advice would be greatly appreciated.
Re: AC Power meter
« Reply #1 on: July 29, 2014, 07:18:32 pm »
I see MicroDAQ might have a solution with their Acuvim-I series. Under $300, investigating that as a start.
I have no experience with that company however..
Offline mjkuwp
  • mechanical engineering defector
    • The Mz Lab
Re: AC Power meter
« Reply #2 on: July 30, 2014, 01:16:50 pm »
What else have you come across?
have you seen this site?
http://openenergymonitor.org/emon/
maybe it is not good for finding products but there may be other resources there.
Do you need logging of the data?  what is the purpose of monitoring power?
I am interested in this topic.  I made my own meter but if there was something relatively low cost I would just buy them.
Re: AC Power meter
« Reply #3 on: July 31, 2014, 06:08:45 pm »
We do not need data logging at this time, but may someday. The power meters we use now were a home brew and are really showing their age (20+). This will be used in a lab that teaches how to use current and potential transformers for measurements and demonstrates the function of an isolation transformer.
