Author Topic: AC source fast short circuit protection device  (Read 7594 times)
Offline semir-tTopic starter
  • Country: ba
« on: February 07, 2024, 12:17:42 pm »
Greeting everyone,
I am looking for a fast short circuit protection device for AC sources that I could use when I am powering my custom PCB boards for the first time. I am not keen on using a fuse and would like to use something faster.
I found one device here but I can't seem to buy it: https://mediadesigns.co.in/product/medis-fast-trip/
Here is the video presentation of their device and this is what I am looking for:
I am hoping that someone knows some similar device that can be purchased.
Offline alm
Re: AC source fast short circuit protection device
« Reply #1 on: February 07, 2024, 02:12:40 pm »
Chroma and HP/Agilent/Keysight make AC sources that can do this and a lot more. They are big and very expensive new, but you can occasionally find a deal used.
Offline David Hess
  • DavidH
« Reply #2 on: February 07, 2024, 02:58:19 pm »
DC short circuit protection can be used for AC by placing it within a bridge rectifier.
A benchtop variable AC power supply should be suitable.  A cheap way to do it would be to get a pair of power transformers sized for your load, and connect them back-to-back; this will just limit the current however.
Offline TheSteve
  • Living the Dream
« Reply #3 on: February 07, 2024, 04:12:07 pm »
This is worth watching:
VE7FM
The following users thanked this post: kripton2035
Offline David Hess
  • DavidH
« Reply #4 on: February 07, 2024, 06:50:48 pm »
That brings up the question of how fast he wants it to be.  100s of nanoseconds is possible.  Relays are quite a bit slower.
Offline ifonlyeverything
« Reply #5 on: February 07, 2024, 06:58:58 pm »
I'm also interested in a similar project. My thought was for MOSFETs upstream of a relay. If the MOSFETs blow up and fail shorted, the relay will save the day.
Offline David Hess
  • DavidH
« Reply #6 on: February 08, 2024, 02:27:45 am »
I would use a fuse instead of a relay as the fail-safe.
I think I would use a pair of back-to-back power MOSFETs to switch AC directly with a photovoltaic optocoupler to supply the turn-on bias.  For a fast turn-off, I would include a separate optocoupler to drive an SCR (probably a pair of bipolar transistors making an SCR) to short out the gate drive.  Now the control circuit is completely galvanically isolated from the power switch, so it can be placed anywhere convenient to measure the current.
Big TO-247 power MOSFETs are not too expensive and I think would survive shorting out a 15 or 20 amp standard 120 volt AC circuit until a fuse blew or breaker tripped.
« Last Edit: February 08, 2024, 02:30:57 am by David Hess »
