Author Topic: SPD3303 Terminal spacing  (Read 901 times)
Offline gogomanTopic starter
« on: August 23, 2021, 05:35:23 am »
Hello the SPD3303 output terminal spacing is wider than the standard banana to BNC connector. Is a wide version of the the banana plug available which connect to  the plus and minus terminals.
thanks
Re: SPD3303 Terminal spacing
« Reply #1 on: August 23, 2021, 05:46:32 am »
Yes for these it's 20mm instead of 3/4".
Not aware of 20mm banana to BNC adapter availability.
