The pictures aint consistent, it cycles between 1x and 10x, the vpp-values on the sig-gen, also vary.
It was more an attempt to see how little noise it could muster at relatively low values, the LP-bandwidth filters do make quite an impact...
Yes 1mV/10mA on CC65, scope with 30KHz LP, with averaging and 10 Ohm resistor as load...
The values in itself, take it with a pinch of salt, its 9v battery was down in the high 6v region, so far from ideal but the only 9v I had on hand.
Will try to take a look at both ETCR007A and CC65 when I get some 9v batteries..
CC65 (60A 20KHz) 2 settings. [1mV/10mA & 1mV/100mA]
ETCR-007A (50A 100KHz) 2 settings [10mV/A & 100mV/A]
