Author Topic: AC/DC power/energy meter  (Read 418 times)
Online drummerdimitri
  • Country: lb
« on: October 15, 2018, 05:09:13 pm »
I am having a hard time finding a tool to measure power in both AC and DC.
Ideally I would buy the Metrahit Energy meter but it is very hard to find and a bit expensive since I don't need all the other DMM functions.
I already have a Fluke 345 which I use mainly for High current application since it is a clamp style meter but I need something much more accurate for power and energy reading at low power outputs.
Finding a suitable tool has been frustrating as there seems to be none out there.
Offline R_G_B_
Re: AC/DC power/energy meter
« Reply #1 on: October 15, 2018, 05:19:08 pm »
I have the gossen it does AC power analysis and DC upto say about 10 amps.
If you want to measure higher D.C power you need a later version of the meter with version 2.xxx as they made some modification to allow you to connect a hall effect current clamp to the current input. They sell a D.C power set
https://www.gossenmetrawatt.com/english/produkte/metrahit-energy-dc-power-set.htm
Or
I managed to find a cheap power clamp meter that does kWh, KW, VAR, VA.
Problems is it's not true r.m.s which is a bit disappointing. It also does D.C power which is useful.
https://www.aliexpress.com/item/HoldPeak-HP-870P-Power-Clamp-Meter-Auto-Range-AC-DC-Voltmeter-999-9A-Ammeter-Tester-Electronic/32885509774.html
« Last Edit: October 15, 2018, 05:24:07 pm by R_G_B_ »
R_G_B
