Author Topic: Acopian 10KV High Voltage Power Supply Teardown and Test  (Read 973 times)
Offline sburrell
« on: July 22, 2015, 08:32:05 pm »
On a swap I ended up with with a HV Supply and did some basic tests and teardown (As much as taking off the covers) prior to turn on since its condition was unknown.  If anyone has a source for the connector used in these I'd like find one.  If I had to guess I'd say it would be a GES S series but I can't be entirely sure.  Maybe someone here knows?
DISCLAIMER - HIGH VOLTAGE SUPPLIES CAN KILL YOU
Full Writeup and Video avail at http://www.shaneburrell.com/?p=1089
