Products => Test Equipment => Topic started by: sburrell on July 22, 2015, 08:32:05 pm
On a swap I ended up with with a HV Supply and did some basic tests and teardown (As much as taking off the covers) prior to turn on since its condition was unknown. If anyone has a source for the connector used in these I'd like find one. If I had to guess I'd say it would be a GES S series but I can't be entirely sure. Maybe someone here knows?
DISCLAIMER - HIGH VOLTAGE SUPPLIES CAN KILL YOU
Full Writeup and Video avail at http://www.shaneburrell.com/?p=1089 (http://www.shaneburrell.com/?p=1089)
