Author Topic: Siglent SDS 1104X-E what to do with waveform files?  (Read 1221 times)
Offline oerg866
« on: February 04, 2019, 01:42:18 am »
Hi guys,
I own a SDS 1104X-E and I want to look at a waveform I captured on my computer. I have the binary file saved here, now what do I do with it?
The EasyScope software won't work because I can't install NI-VISA...
No log files, nothing...
so I'm looking for a solution to browse around my waveform capture like this.
Sure I could load it into an audio editor but I don't expect to have to rely on that kind of shoddy kludge after buying a 500€+ product....
Regards,
Eric
Offline BillB
Re: Siglent SDS 1104X-E what to do with waveform files?
« Reply #1 on: February 04, 2019, 01:58:07 am »
Have you tried just installing the runtime?
http://www.ni.com/download/ni-visa-run-time-engine-18.0/7603/en/
Offline oerg866
« Reply #2 on: February 04, 2019, 02:05:05 am »
Just tried that - no luck. Same error :'(
« Last Edit: February 04, 2019, 02:06:39 am by oerg866 »
Offline BillB
« Reply #3 on: February 04, 2019, 02:07:22 am »
Which OS version are you using?
Check out this link - seems to be a known issue:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019YOnSAM&l=en-US
« Last Edit: February 04, 2019, 02:10:11 am by BillB »
Offline oerg866
« Reply #4 on: February 04, 2019, 02:09:00 am »
I'm using Windows 10 Build 17763 (October Update) on a Threadripper 2950X.
EDIT: 64 Bit of course.
Offline tautech
« Reply #5 on: February 04, 2019, 02:27:17 am »
Simplest is to use the Webserver feature while connected to a PC and Save a .bin file.
Then use the scopes embedded file converter utility that downloads to your PC from the scope Webserver in order to convert the .bin file to a .csv file
Then you can drop all or part of the waveform .csv file info into your favorite program like say Excel for graphs, charts etc.
A tip; set memory depth and timebase so to not get massive file sizes.
A demo of this ^ I did for a customer, we used a Single trigger setting so just get one screen's worth of data.
Note.
All done with the latest FW V6.1.26 and the new scope OS with the improved Webserver on a Win7 laptop.
Edit to add:
https://www.siglentamerica.com/video/binary-to-csv-x-e/
« Last Edit: February 04, 2019, 02:39:16 am by tautech »
Avid Rabid Hobbyist
Offline oerg866
« Reply #6 on: February 07, 2019, 09:22:03 pm »
Got the bug figured out. Windows 10's October Update version seems to have a problem with regex parsing of some sorts.
I figured this out because all my recent problems persisted after re-formatting and installing the latest build.
  • NI-VISA couldn't install
  • FTDI's FT_Prog crashed as soon as you scanned the bus
  • Xilinx ISE 14.7 wouldn't install because of invalid installation paths:
  • Xilinx ISE wouldn't build my FPGA project because of a regex parsing error ("false" apparently isn't "false" anymore?)
    Mind you the same project built just fine on my non-updated laptop.
I've reverted to the April build and now my system runs smoothly, NIVISA is installed and my scope works :)
Offline acugnini
« Reply #7 on: May 26, 2020, 05:48:42 pm »
Is it possible to upload a waveform to the SDS1202X?  I know downloading is possible, using either EasyScopeX or by opening an IP socket, but what about the reverse?  (I want to upload a waveform and then perform an FFT on the data.) --agc
« Last Edit: May 26, 2020, 05:58:31 pm by acugnini »
