Author Topic: Hacking the Victor VC-921  (Read 19903 times)
Offline itsthatidotagain
Re: Hacking the Victor VC-921
« Reply #25 on: May 30, 2017, 11:55:34 am »
If anybody has a bit of spare time and wants to hack another DT0660 based meter, they might like to take a look at the
http://www.ebay.co.uk/itm/302325367550?_trksid=p2055119.m1438.l2649&var=601161562576&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_nkw=zt+102+multi+meter&_sop=15
AN8002 also known as the ZT102 and the RM102 and others.
This is actually quite a good value and reasonably robust meter.
It differs from the VC912 in that the pads for the COB are not all broken out, so the pins for the IR serial port may not be available.
Offline TheRadioGeek
    • YouTube Channel
« Reply #26 on: August 30, 2017, 11:49:28 pm »
Hello all,
I am new to all this software EEPROM stuff and have some questions. I have a VC-921 pocket meter that I would like to change the EEPROM to allow it to be 8000 count and maybe change the auto power off time. I have a Minipro TL866 universal programmer and was able to read the eeprom and get the following. I however don't know what to change to get the above unlocked. Could someone tell me what I need to change and how do you find out what to change and what to change it to when doing something like this.
Thanks
FF FF FF FF FF FF FF FF FF 52 00 FA 00 00 BE 03
A0 0F 68 10 7C 01 6E 50 64 4B 3C 3C 0A FF 40 FF
80 98 F1 81 64 00 96 00 00 80 00 80 00 80 00 80
4E 02 09 58 05 09 1D 04 0B B9 11 0A 7B FF 09 00
00 01 00 01 00 07 98 00 64 00 64 00 64 00 00 00
00 80 00 80 00 80 00 80 00 80 00 80 00 80 00 80
7D 7F 00 83 01 00 81 2A 00 00 00 00 00 00 00 00
08 81 00 80 8A 82 E0 7C 18 01 00 00 00 00 00 00
00 00 00 06 00 00 00 05 00 07 00 0A 12 09 0B 0E
00 00 00 00 00 00 00 0D 00 02 11 0F 00 00 00 15
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0D 00 02 10 0D 00 03 20 20 00 03 20 20 00 03 10
41 00 03 08 41 00 03 05 41 00 03 05 0D 00 02 20
3C 7F FF FF FF FF FF FF 5A C7 CC 0F 0F 80 00 00
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #27 on: August 31, 2017, 12:14:53 pm »
In the datasheet of the chipset is everything you need.
You just need to open a .bin file and change it and reflash the eeprom with the changed .bin file. I cant think of other solutions with a TL866.
It got a VC921 too, and this is where I'm stuck atm....
Sent from my A0001 using Tapatalk
http://rbastlerblog.jimdo.com/
Gamma spectrometer works. Now some yellow crystals need regenerating and testing.
    • YouTube Channel
« Reply #28 on: September 01, 2017, 12:16:45 am »
Hey guys and gals,
I got my vc 921 to be a 6000 count meter thanks to the data sheet from http://www.kerrywong.com/2016/04/03/dtm0660-datasheet-translated/ . It's for the dtm0660 chip that this meter has under that blob.  I did try to change the auto off time but it gave me an error when I tried to program  the EEPROM.  I took a screen shot of the programming changes. changes are in RED. The one red one at the bottom was me trying to change the auto off time. It has the default of 0f.
thanks Rbastler
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #29 on: September 01, 2017, 07:32:56 am »
How did you manage to make the changes in the eeprom ? I cant figure out how. Is it possible right with the tl866 ?
    • YouTube Channel
« Reply #30 on: September 01, 2017, 11:42:15 pm »
You will need a SOIC 8 dip to clip cable. see photo. You hook up the cable to the ZIF socket on the programmer and clip the other end on the legs of the EEPROM on the PCB. Make sure pin 1 is lined up with pin 1 on the cable. Red stripe is pin 1 on the cable. On the programmer pick Atmel 2402 and hit the read button. Save what you read  from the chip to a bin file just in case you mess things up and need to load it back into the chip. Make your changes by clicking on the address you want to change and typing in the values you want. Now push the program button and you should be all set.  I got my cable on Amazon for about $10 but I'm sure you can find it on Ebay too. Try a search for SOIC 8 clip programming cable.
Hope that helps. 8)
Good luck.
The following users thanked this post: Rbastler
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #31 on: September 02, 2017, 10:52:35 am »
Hope that helps. 8)
Good luck.
Yes, that did help !  :-+
Didn't knew you could modifie EEPROM content in the MiniPro software.
I bought a Soic adapter cable, when I bought the VC921 on Aliexpress, so no problems there.
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #32 on: September 02, 2017, 03:08:58 pm »
Here my successful attempt at modifying the EEPROM for more counts plus a comparison to my Fluke 8050A measuring a quick and dirty AD584 reference:
    • YouTube Channel
« Reply #33 on: September 07, 2017, 12:54:42 am »
Nice photos of the modified meter in action. I am glad you got it all working. I got mine set to 8000 count as well. I made a how to video if anyone wants to see how its done. DO THIS AT YOUR RISK.
Its kind of neat that you can change this stuff!!  Fun fun  :-+ :-DMM
Offline necromncr
« Reply #34 on: February 16, 2018, 10:29:12 am »
Just wanted to add - Zotek ZT102 has a button placeholder on the back of the PCB called RANGE. It actually works and switches AUTO to MANUAL range mode!
Offline sarel.wagner
  • Cooking up an Electronix Storm
« Reply #35 on: March 06, 2018, 03:52:04 pm »
This time a really really simple hack. The lead storage for Lab use is silly, so I cut a piece out of the case for the leads. Now I can close the lid without worrying about trying to store the leads.
Youtube short video here https://youtu.be/pQweOiUN2hI
Offline SandPox
« Reply #36 on: April 22, 2018, 02:20:30 pm »
Hey, I just found that you can enter calibration mode on VC921 by holding REL and RANGE button while it's turned on, switch off and then switch on the meter, it will beep few times while display all the character on the screen then it will enter "CAL" mode with some weird looking character, I worry that I might mess up the calibration of my meter so I switched it off immediately, it still seems fine though
« Last Edit: April 22, 2018, 02:24:59 pm by SandPox »
Online Fungus
« Reply #37 on: April 22, 2018, 03:28:48 pm »
Didn't work on mine...  :popcorn:
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #38 on: April 22, 2018, 08:02:44 pm »
Not on mine.... Afaik you need to short two pads in order to get into cal mode.
Offline SandPox
« Reply #39 on: April 23, 2018, 08:44:11 am »
Somehow I was not able to enter it anymore, the screen blinking with all character and beeping but it never ends.. huh, strange!
edit: sometimes I power it up while holding two button and it only display APO REL but the number doesn't show up, maybe it enter some kind of secret mode?
« Last Edit: April 23, 2018, 08:49:36 am by SandPox »
Offline dacson
  • Country: at
« Reply #40 on: June 19, 2018, 07:10:15 pm »
I ordered a Victor VC921 recently (24.05.2018), after i only found offers for the Zotek VC921/Aneng 8203 for a while, which is based on a different chipset/design afaik. I was a little bit afraid that the seller didn't know the difference and that i might instead receive a Zotek/Aneng "clone". To my surprise, i really received a Victor VC921, with the tall numbers on the display and the oval buttons.
But what's really interesting is that it came with the DM1106EN as QFP instead of as COB, just like in my UT210E. Not sure if this changes anything in regard to hackability as all pins seem to be in use anyway, so i guess a COB would have had all pads bonded as well. Still, i prefer this over a COB with (maybe) unbonded pads under the black gunk.
What i don't like is the bend PTC with its bare feet coming quite close to the (i guess) clamping transistors. Solved that with some kapton tape until i have access to my iron again.
Edit: Actually, on a second glance, four pins seem to be unused and could potentially be unbonded on a COB. And sorry that this is more of a teardown post, i have a second unit in the mail that i will hack, once i have access to my tools again, and report here.
« Last Edit: June 23, 2018, 01:26:09 am by dacson »
