Author Topic: Rigol DS2202 possible bug.  (Read 1978 times)
Offline zenerTopic starter
« on: June 15, 2013, 04:00:21 pm »
I have a DS2202 with the original firmware 00.00.1.   I was trying to set the 2 GSa/s sample speed
and the 14 Mpts buffer depth.   If I set sweep speed to 500uS I can get it on chan 2 but not chan 1.
This is, of course, with only one channel enabled at a time.   I turn on chan 1 (only) and it says
1 GSa/s and 7 Mpts.   If I change it to chan 2 (only) it says 2 GSa/s and 14 Mpts.    Am I doing
something wrong?   Why don't both channels operate in the same manner?
If I enable both channels I get 1 GSa/s and 7 Mpts as expected.
Thanks,
Pete.
Online egonotto
Re: Rigol DS2202 possible bug.
« Reply #1 on: June 15, 2013, 04:35:28 pm »
Hello,
I think this is no error. I think your triggersource is ch2.
If ch1 is the only chanal you have to set the triggersource to ch1. Then you will have what you want.
Best Regards
egonotto
« Reply #2 on: June 15, 2013, 04:43:46 pm »
Yes, that is it!   I am happy to learn something new.
Thanks,
Pete.
Offline PA4TIM
« Reply #3 on: June 17, 2013, 05:47:12 pm »
Chinese scopes have no bugs, only features  >:D
« Reply #4 on: June 17, 2013, 05:55:57 pm »
And mostly undocumented ones at that.  :-DD
At least is did not do what is so common and blow up. I saw one comment on an exploding Chinese chair that asked if there is anything Chinese made that does not blow up at some point or the other.
