Author Topic: AD9854 100 MHz function generator from eBay  (Read 10939 times)
Offline zibadunTopic starter
« on: November 13, 2012, 05:26:00 am »
Ran across this listing http://bit.ly/QCX2zQ
Does this look like a good buy or is it a hundred bucks down the drain?  I'm a ham and looking for a basic two channel generator 1-30 MHz or so
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: AD9854 100 MHz function generator from eBay
« Reply #1 on: November 13, 2012, 05:36:59 am »
first its old serial. 2nd the software is chinese.
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #2 on: November 13, 2012, 05:45:22 am »
The AD9854 itself is around $30 from Digikey, and is capable of being clocked at 300MSPS. 100MHz is probably about right. Considering the work that goes into the design and manufacture, $100 is probably worth a shot.
I can't comment on the schematic, because its not letting me download it.
Offline poptones
« Reply #3 on: November 13, 2012, 06:30:57 am »
Why not combine one of those $5 modules with a $10 arduino nano and make your own usb version?
« Reply #4 on: November 13, 2012, 01:21:27 pm »
I managed to pull down the schematic - https://dl.dropbox.com/u/28207218/generator/Schematic%20Prints.pdf
Looks like it's the DDS chip with output filters and an Atmel controller and not much else
the RS232 port doesn't bother me. It can be easily fixed with a usb converter module.  There is a source code for the atmel included, with comments in Chinese :(
  • Country: my
« Reply #5 on: November 13, 2012, 02:11:12 pm »
the signal goes out directly from the dds chip to sma with just some passive filters in between, look bad to me, whats the ad9854 output magintude? ±1V and no offset control? if you are me i'll buy the $5 kit and program the arduino myself AD9850 Module and DDS3x25 DDS based FG Compared the problem is.... you are not me ;)
edit: and 1Kohm output impedance? you got to be kidding me.
« Last Edit: November 13, 2012, 02:22:14 pm by Mechatrommer »
Offline grenert
« Reply #6 on: November 14, 2012, 05:19:14 am »
Maybe one of these and some of those ebay 9850 modules will work for you:
http://www.pongrance.com/DDS-9850.html
  • Country: my
« Reply #7 on: November 14, 2012, 05:28:12 am »
the recent Ascel AE20125 Function Generator Review and Teardown is even better. $70 with casing and both standalone + pc control capability, proper output circuit, triangle fsk etc. but it will distort at 10MHz, so YMMV.
« Reply #8 on: November 14, 2012, 01:04:09 pm »
Thanks for the links.  After reading various posts here it looks like 3x25 would be the right choice for me...
