Author Topic: Micsig Tablet Oscilloscope tBook mini TO1104 review (100Mhz 4 channel 'scope)  (Read 54847 times)
Offline Pfriemler
It looks for APK files but if you try to install one it says, "Install Blocked: Your administrator doesn't allow installation of apps obtained from unknown sources".
Maybe we could ask Micsig about this. I want to turn mine into a huge HP15C.
Did anyone?
I would like to run additional apps on the android surface, like
- File Manager with FTP upload (Total Commander with ftp plugin) or something like that
- Electrodroid - like the Electronic Tool, but much more informations inside
- a PDF reader (for the user manual there must be something like that, but PDF on a USB device do not open)
If there's any workaround, I would higly appreciate this.
once you do it right, it works :-)
